How Does Field Current Affect DC Motor Speed?
  • Topic: Engineering
  • Thread starter Michael Neo
    Change Speed
4 replies · 3K views · last reply
Michael Neo
A 250 V shunt motor has an armature resistance of 0.4 Ω and runs at a speed of 750 rev min –1 when taking a full load current of 25 A.
Estimate the speed of the motor at no load when the armature current is 3 A, assuming that the flux per pole remains constant.
Back EMF:
E=V-Ia*Ra
Field Current:
If=Il-Ia
Field Resistance:
Rf=V/If
Change in Speed:
Old speed = (New speed)*(V-If*Ia)/E
Field Current
If=25-3
If=22 A
Field Resistance
Rf=250/22
Rf=11.36363636 Ohms
Back EMF
E=250-3x0.4
E=248.8 V
New Speed
New Speed = (Old speed)*(V-If*Ra))/E
New Speed = (750)*(250-22*0.4)]/248.8
New Speed = 727.0900322 rpm
Where can I find the appropriate formula for the change in speed in this scenario?
I have searched several books.
Field is shunt connected, so If is determined by supply voltage, V.
On no load, we usually consider Ia to be zero.
The shunt motor under load will be slowed down from its unloaded speed.
So, at zero load the shunt motor will speed up.
The numbers substituted in are correct; therefore, the formula is incorrect.
A different approach is required - but which one. I cannot find this formula anywhere.
After a sleepless night:
Motor speed N = K*(V - IR)/φ
In this case, where flux is constant,
N2/N1 = (V - Ia*Ra)/(V - Il*Ra)
So,
N2 = N1 * (V - Ia*Ra)/(V - Il*Ra)
N2 = 750 * (250 - 3*0.4) / (250 - 25*0.4) = 777.5 rev/min
That is correct.
