How Does Internal Resistance Affect Battery Performance in a Car?
  • Thread starter Thread starter mutineer
    Internal
3 replies · 6K views · last reply
mutineer
"A car battery has an e.m.f. of 12V and an internal resistance of 0.04 Ω. The starter motor draws a current of 100A. a.) What is the terminal p.d. of the battery when the starter motor is in operation? b.) If the headlamps are rated at 12V, 36W, what is their resistance? c.) To what value will their power output decrease when the starter motor is in operation?"
E=I(R+r)
The first two answers are easy to get. 8V and 4ohms. I can't get the last one( the lamps I am assuming are in parallel). The book says the answer is 16W.
with motor, terminal voltage drops to 8V
power through lamps is [itex]V^2/R[/itex]
The question as stated has a few problems with being vague. It states that the starter motor draws 100A, but is that its rating with an ideal 12V source or is it with the given "imperfect" battery with a 0.04Ω series resistance? Does it thus draw 100A at 8V?
When the headlamps are switched on they will draw additional current through the battery's series resistance, so that voltage drop will be slightly larger; The starter motor will not be getting the 8V it did before. Will it still draw 100A?
These considerations can make a small but noticeable difference in the result. The book result seems to ignore these details and assumes that when the lamps are switched on, no additional current is drawn from the battery over the 100A that were being drawn previously.
@Gneill: it is a set question. We are told that the starter motor draws 100A ... we are not told how that is determined, true, but determined it has been[*]. It is not given as a "rating", but as one of the facts of the problem.
It is drawing 100A - what is the terminal voltage? See? Not vague.
The terminal voltage must be 8V for it to draw 100A ... modeled by working out the effective resistance of the motor. If it were drawing 0A, the terminal voltage would be 12V.
The headlamps, according to the book answer, draw an additional 2A. (16W, 8V, => 2A)
However - the lamps are an additional load on the battery so the terminal voltage should be further reduced. - I get 7.8957V instead of 8V... but we can only keep 1 significant figure - thus 8V it is. (@mutineer: working this out would probably be worth marks.)
So turning on the lamps does not make any noticeable (within margin of error) difference.
The model is a bit dodgy - real lamps' resistance depends on applied voltage (and temperature), and the motor is unlikely to be so well behaved either.
[*] this is not unusual - physics problems very often provide figures without mention of how they were obtained. Quite a lot can hinge on a single word, or absence of one (in this case).
