How Does Local Measurement Affect an Entangled System?
54 replies · 8K views
nojustay
TL;DR
I don't understand entanglement
Hi, I am doing my thesis on quantum entanglement and I don't seem to wrap my head around what really happens to an entangled system during a local measurement. I happen to know that information can't travel faster than light I could believe that the collapse of the wave function wouldn't allow us to really extract any relevant data. Yet, the particles themself "know" about the collapse and act accordingly. For example, the decay charmonium -> K_s K_s never happens even in space separated regions.
Quantum entanglement is a big field. Do you have a specific question?
You mention doing a thesis on entanglement. I would recommend you read up on standard photon entanglement theory and experiments. Most of these use Parametric Down Conversion to create and study entanglement. Exotic particles (such as charmonium) are not a good place to start.
nojustay said:
TL;DR Summary: I don't understand entanglement
Collapse is just one of many interpretations. The particles don't act accordingly. That's a misconception based on classical reasoning.
"I happen to know that information can't travel faster than light"
That doesn't apply in nonrelativistic quantum mechanics.
Reply
  • Skeptical
I am interested in that charmonium decay. Do you have any source on that?
My take with entanglement is an MWI like view. But that's just interpretational, to give a mental picture to "what happens".
Entanglement is just the phenomenon that non-product states of compound systems generate different correlations between the subsystem observed probabilities according to the basis in which one looks at the subsystems (that is to say, according to the different incompatible measurements one actually does to the subsystems).
If you don't want to go "MWI" you can't really attach much "physical reality" to wavefunctions: you have to see it as a device that generates probabilities for measurements.
If you have a state ## |A_1> \otimes |A_2> + |B_1> \otimes |B_2> ## then you would get, if you measure systems 1 and 2 in the basis ## \{ |A>, |B> \} ## probabilities of 1/2 for (A,A) and 1/2 for (B,B) outcomes, and probability 0 for outcomes (A,B) and outcomes (B,A).
Up to now, there's no distinction between a classical mixture with these probabilities, and this quantum state. There's no particular "indication" of entanglement. You get a classical correlation, where system 1 has 50% chance to be in state A, and 50% chance to be in state B, and system 2 is perfectly correlated with system 1.
The weird things start to happen when you measure system 1 and system 2 in different bases. Your entangled state will still provide you with the probabilities of the combined outcomes, and these probabilities will still be "Kolmogorov standard probabilities". However, what fails is to assume that the outcomes of contrafactual measurements are still described by Kolmogorov probabilities. (that's essentially Bell's theorem).
Nevertheless, once you have determined your measurements (the bases you will use), the quantum entangled state will spit out the correct set of Kolmogorov probabilities for the combinations of outcomes.
The essence of entanglement is that you can't have a Kolmogorov probability set for contrafactual measurements a priori.
Sargon38 said:
1. The weird things start to happen when you measure system 1 and system 2 in different bases. Your entangled state will still provide you with the probabilities of the combined outcomes, and these probabilities will still be "Kolmogorov standard probabilities".
2. However, what fails is to assume that the outcomes of contrafactual measurements are still described by Kolmogorov probabilities. (that's essentially Bell's theorem). ... The essence of entanglement is that you can't have a Kolmogorov probability set for contrafactual measurements a priori.
Your description of entanglement oversimplifies in a manner that IMHO won't help the general reader.
1. When you measure on the same bases, there are perfect correlations (a la EPR). And when you measure on different bases, there is nothing about "Kolmogorov probabilities" that enters the picture at all. QM is contextual, and the Kolmogorov probabilities you are referring to only come into play when you consider counterfactual reasoning associated with non-contextuality (realism) - if they are to be considered at all.
The quantum prediction for entangled systems is strictly statistically related to those bases (same or different). As far as is currently known, there is no other variable (or set thereof) that determines or influences the expected results in any way. Only a future context matters, regardless of the size (separation) of the entangled system.
2. I would never describe Kolmogorov probabilities as having anything to do with the essence of entanglement. You mentioned in your post (to the effect of) that an entangled system cannot be considered as 2 individual systems, since by definition entangled systems cannot be represented by a Product of 2 systems. Agreed, that is more the essence of entanglement.
Likewise, I wouldn't say Kolmogorov probabilities have much to do with Bell. It is the assumptions of locality and realism (counterfactuals) that constitute Bell. If you want to say Bell also assumes Kolmogorov probabilities, then fine. I would say those are also assumed for most of science, nothing particular about Bell. All possibilities must add to 100% when counterfactuals are possible - which of course does not always apply in QM (as Bell demonstrated).
Reply
My point was: when one doesn't change bases then there's strictly no difference between "classical" (Kolmogorov) correlations and entanglement. The "weirdness of entanglement" only shows if one changes bases, and one is going to perform incompatible measurements. That's, I suppose, what you mean by "contextual".
For instance, if one has an entangled spin state of two particles, and one keeps measuring particle 1's spin in, say, the X direction, and particle 2's spin state in the Z direction, then this can perfectly be described by a classical correlation between the X spin result of particle 1 and the Z spin result of particle 2, which is the set of probabilities one obtains when projecting the entangled state in the basis of ## X \otimes Z ##. The projections provide you with "normal" Kolmogorov-type probabilities.
It is only when you "change basis" and, say, analyse this system ALSO in the ## Y \otimes X ## basis, say, that you WOULD get "weird, non-Kolmogorov" type probabilities (violating Bell's inequalities) if you assumed counterfactually that the previously calculated probabilities in the other basis were still valid too. But this is counterfactual, because you cannot do the measurements *simultaneously* in both bases.
But it is the appearence of these "counterfactual" non-Kolmogorov probabilities that characterize entanglement as opposed to "statistical mixture". It is what separates the entangled state from the reduced density operator.
As long as you don't consider the system in different bases, you can't make the difference. That was my point: that it is this "weirdness" that appears in true entangled superpositions, which is absent in statistical mixtures, which is the essence of entanglement.
It is what makes quantum mechanics fundamentally different from just statistical mixtures, but it only appears in counterfactual situations. As you said, any actual measurement will always be satisfying normal Kolmogorov probabilities, derivable from the quantum state in the basis of observation.
It is exactly this absence of the possibility of a (normal hence Kolmogorov) probability distribution of hidden variables that characterizes entanglement. That was my whole point.
Well, it is exactly the impossibility of Kolmogorov probabilities for all possible outcomes of measurements on entangled states that characterizes entangled states, that was my point.
That is a strange statement, because Bell's inequalities are based upon standard (Kolmogorov) probability theory, and Bell's theorem is exactly the statement that any objective a priori description of individual subsystem states in an entangled system that would yield the measurement outcomes would need probabilities that violate these inequalities.
So to me, normal Kolmogorov probabilities are central to what Bell expressed, and what Bell expresses is probably the most characteristic aspect of entanglement.
Bell's Theorem was the death knell for local hidden variables and entanglement and tests of Bell's theorem provided a great experimental result for QM. The underlying principle of QM of using (complex) probability amplitudes, as opposed to classical (Kolmogorov) probabilities, was already well established. To explain the double-slit experiment, the Stern-Gerlach experiment etc. Moreover, particle scattering calculations explicitly calculate a probability amplitude first.
In fact, the popular wave-particle explanation for the double-slit plays on the lay person's need to think in terms of concrete probabilities: the electron is definitely a wave; then it is definitely a particle etc. The correct QM calculation that involves complex probability amplitudes is side-lined.
In summary, even without entanglement, you cannot maintain an interpretation of QM that relies on classical probabilities at each stage.
The issues about entanglement theory per QM have nothing to do with the classical world. The OP is trying to understand what entanglement is, not what it isn't - "I don't understand entanglement". I think it is just as amazing that perfect correlations exist, because that might imply that (as EPR claimed) QM is incomplete - when Bell shows it is not.
Again, I have no idea why you are focused on Kolmogorov. That is virtually never discussed in treatments of entanglement or Bell, mainly it is discussed by Bell deniers (which you are not). If you can even find a reference in the Bell 1964 paper that remotely makes this a relevant topic to this thread, I'd be interested to see the quote.
At any rate, there is far more to entanglement than Bell (although I think it is mandatory for any hope of understanding entanglement). 35 years ago we got the GHZ Theorem. In that, there are no statistical issues (as in Bell) that might remotely relate to Kolmogorov ideas. Every single outcome of every trial is exactly the opposite of what a classical perspective would predict. And of course, in perfect agreement with the predictions of QM.
Reply
PS Not that it proves anything*, but I searched for "Kolmogorov" in Stanford's Plato for these pages:
Bell's Theorem
Quantum Entanglement and Information
Philosophical Issues on Quantum Theory
Total hits: 0. There isn't even a page for Kolmogorov.
*Well, actually it does... :smile:
Bell's Theorem
To be fair, Kolmogorov is just another name for classical probability theory.
Reply
Yes, but the whole thing about Bell was exactly that two different subsystems (with the potential of being spatially remote) could be in a state that was NOT to be described by a statistical mixture. That was the exact content of Bell's theorem, and to me, the essence of what one calls entanglement.
Entanglement as distinguished from statistical mixture. It is exactly the feature of not being describable by (counterfactual) Kolmogorov probabilities that renders entanglement different from statistical mixture (by definition I would say). If all measurable properties of subsystems were describable by a statistical mixture, there wouldn't be anything special about "entanglement". It would have been just a fancy way to express statistical correlations. It is exactly because this is NOT possible that entanglement "stands out" as, well, entanglement.
But, as I said earlier, that is of course only visible if one uses counterfactual situations, because quantum mechanics ALWAYS delivers "normal probabilities" for a given realisable measurement. So in order to see the particularity of entanglement, namely that it is NOT just "statistical mixture", it is essential to look to the state (mentally) in non-compatible bases (exactly to obtain counterfactual situations).
To me that is exactly what entanglement (as opposed to statistical mixture) is about.
That's what I mean by "Kolmogorov", to distinguish this from some other, weird, "quantum probability" concept. I mean by Kolmogorov probabilities, standard, textbook, statistician, probabilities.
Sorry for the confusion, I thought that it would rather remove them.
States in QM are generally not statistical in the classical (Kolmogorov) sense, but statistical in the sense of having complex probability amplitudes.
Agreed :smile: and that's why I said it's common for most areas of science. "those are also assumed for most of science, nothing particular about Bell."
No, it isn't. Bell's theorem itself has nothing whatever to do with states that can't be described by statistical mixtures. Bell's theorem itself is entirely about what kinds of correlations can be produced by states that can be described by a statistical mixture. More generally, theorems like Bell, GHZ, etc. are about what kinds of predictions can be produced by models that satisfy the kinds of assumptions that you are referring to when you use terms like "statistical mixture" (although, as @DrChinese has said, in cases like GHZ the predictions aren't statistical at all).
It is the fact that the predictions of QM, and now many experimental results confirming those predictions, are inconsistent with the predictions that can be produced by models that satisfy the conditions of the above theorems, that you are referring to by the term "entanglement". But that very fact invalidates any discussion of the actual QM predictions, and the actual experimental facts, in terms that make the kinds of assumptions described above. The implication of the actual experimental facts is that the real world does not satisfy those assumptions.
This is not correct. The fact that QM predictions and the actual experimental facts violate the Bell inequalities, the GHZ predictions, etc. can be, and has been, confirmed without any resort to counterfactuals at all. The predictions are about what we will actually observe when we do actual experiments; there is no need at all to drag in claims about what we would have observed if we had done different experiments.
Reply
Quantum predictions are what matters in discussions of entanglement. Are you saying those are weird? What one person labels "weird" might be quite different than another.
Ah, I thought that Bell's inequalities are what you are referring to, and that Bells' theorem was that certain entangled quantum states violate these inequalities if we produce counterfactual probabilities and correlations when looking in different non-compatible measurement bases.
Now, I should look it up again. Bell's inequalities are inequalities that all classical (Kolmogorov) correlations must satisfy. The (counterfactual, because calculated in different bases) correlations that one obtains from certain entangled states violate these inequalities, and I thought that this was what Bell's theorem was about.
Maybe some people call Bell's inequalities "Bell's theorem", I didn't remember it that way.
My whole point in this thread was, that it is exactly THIS violation of the possibility of describing the system by a statistical mixture (which is exactly what the violations of Bell's inequality are about) are the VERY ESSENCE of what one calls "entanglement" (which was the OP question).
If it wasn't for such impossibility to describe an entangled state by a statistical mixture, then entanglement wouldn't be anything particular. It would be a fancy way to say that we have simply a statistical mixture of "couples of outcomes". It is because exactly that is not possible, that entanglement is what it is.
Yes, that's what I'm saying from the beginning, that is EXACTLY what entanglement is. Otherwise it would be simply a statistical mixture, and there wouldn't be anything fancy about "entanglement".
I'm having myself a counter factual observation in this thread, that I'm saying "what makes entanglement what it is, is exactly the non-existence of counterfactual classical (Kolmogorov) probabilities of all (counterfactual) outcomes" and I get a list of people saying "no no no, you are wrong, in quantum mechanics, there are no classical counterfactual probabilities ! " :oldbiggrin:
Your usage of the term "statistical mixture" does not provide meaning here, it is another confusing usage. The normal terms related to entangled vs separable (non-entanglement) systems are "Entangled State" statistics and "Product State" statistics. It does not make sense to use the word Kolmogorov in any manner here at all. You may as well talk about the assumption that 1+0=1. Not relevant.
Similarly, the usage of the phrase "normal probabilities" is confusing at best. QM makes predictions that can be tested, not sure what is normal or not about them. It is possible you are referring to "normalizable" or similar, but again that has no bearing at all.
There are plenty of interesting issues around entanglement, and the one you seem to be focused on is pretty low in any discussion on the subject I've seen. How about quantum nonlocality? I would say that is pretty high - and certainly more interesting. That's certain to generate debate amongst followers of different interpretations (which of course should only debated in the related PF subforum).
Reply
What I'm saying is that even without considering entanglement, we have non-classical QM with non-classical probability theory. It doesn't need entanglement to make nature quantum mechanical.
The Bell inequalities only hold assuming a common single probability universe for outcomes that are counterfactual, that's the whole point of it. If you do not consider counterfactual situations in the same probability universe, then you cannot derive Bell's inequalities. It are not the real world experiments that are counter factual (of course !), it are the hypotheses you have to make to derive Bell's inequalities.
In order for Bell's inequalities to hold, you have to consider that there is a single probability distribution over a universe that contains AS WELL the +X outcome, as the +Z outcome of particle 1, say. That's counterfactual: you can't measure AS WELL the +X outcome as the +Z outcome. It is ASSUMING that you could, that you can derive Bell's inequalities concerning the correlations of outcomes. This "single universe" with its single probability distribution is materialized by the probability distribution assumed over the "hidden variables".
It is this which is counterfactual.
Sargon38 said:
1. Ah, I thought that Bell's inequalities are what you are referring to, and that Bells' theorem was that certain entangled quantum states violate these inequalities if we produce [assume] counterfactual probabilities and correlations when looking in different non-compatible measurement bases.
2. Bell's inequalities are inequalities that all classical (Kolmogorov) correlations must satisfy.
3. I'm having myself a counter factual observation in this thread, that I'm saying "what makes entanglement what it is, is exactly the non-existence of counterfactual classical (Kolmogorov) probabilities of all (counterfactual) outcomes" and I get a list of people saying "no no no, you are wrong, in quantum mechanics, there are no classical counterfactual probabilities ! " :oldbiggrin:
1. As revised, this is basically accurate. Locality must also be assumed. Bell's Theorem in a nutshell:
"No physical theory of local Hidden Variables can ever reproduce all of the predictions of Quantum Mechanics."
2. Notice that the above has nothing to do with probability theory. It's no more complicated than: 1/3 + 1/3 + 1/3 = 100%. No need to throw poor Kolmogorov's name around.
3. As it relates to Bell, QM does not have anything to say about counterfactuals at all. Only those who believe that QM is incomplete (in the EPR sense) care about those. EPR specifically discusses counterfactuals in their conclusions.
No, that's not what Bells' theorem says. Bell's theorem is that any model that satisfies certain assumptions must make predictions that satisfy certain inequalities (the Bell inequalities). The fact that QM's predictions violate those inequalities means that QM, as a model, cannot satisfy the assumptions of Bell's theorem. And since QM's predictions have been experimentally confirmed, the real world itself cannot satisfy the assumptions of Bell's theorem.
It's not just a matter of statistics, as has already been said. Bell's theorem itself was about statistical predictions, but other theorems of the same general class, such as GHZ, are not. So just saying "we can't describe actual entangled quantum systems in the real world by statistical mixtures" does not fully convey the facts.
Even if this is the case for Bell's theorem (I believe the literature generally refers to what you are describing in the assumptions of that theorem as "counterfactual definiteness"), it is not the case for other theorems in the same class, such as GHZ. The GHZ predictions are not about statistics but about scenarios where you make a binary measurement, the "classical" model says you get one result, but QM (and actual experiment) says you get the other. No statistics, no counterfactuals. Just a straight yes/no test.
Quantum mechanics always spits out Kolmogorov probabilities for all measurable quantities. QM never produces "non-classical" probabilities in non-counterfactual situations. You always get "normal" probabilities over any complete set of compatible observables.
But my point from the beginning was what sets out ENTANGLEMENT from a statistical mixture of the sub systems, is exactly that you get non-standard probabilities (or call it, broken probabilities) if you DO consider counterfactual measurements on the subsystems. If not, there wouldn't be any point in considering entanglement in the first place: we could just as well study simply statistical mixtures of product states.
So it is the very existence of these counterfactual violations of "standard probabilities" that set entangled states apart from statistical mixtures.
That was my answer to "what is enganglement".
This is not how the historical derivation of counterfactuals occurred. It went from EPR (1935) to Bell's counterargument (1964). It was EPR that raised the idea of counterfactuals, and they specifically mention that they would not have achieved their conclusion (QM is incomplete) without assuming them. Bell is an attack on EPR, not on QM. Of course, it could have led to the discovery that QM was wrong too. :smile:
You are trying to pick out one element of the Bell proof as if it is the only one that matters. And it is probably the least interesting element (that classic probabilities sum to 100%). Not what I would call a burning issue.
This is literally gibberish wrong. For entangled photon polarization experiments, the QM match prediction is cos^2(A-B). Nothing to do with Kolmogorov, standard textbook probability theory, or anything else that you have mentioned.
I see what you mean. It was the emphasis on probabilites, rather than correlations that I didn't follow. I guess it amounts to the same thing.
PS although I'm not convinced that the Kolmogorov axioms themselves are violated. Because, at the end of the day, the axioms of probability theory don't know what physical assumptions are allowed - like non-locality. I'm not convinced that physical non-locality breaks probability theory. And, if it does, which axioms fail?
I think it's better to say that the correlations predicted by QM cannot be sustained given the physical assumptions of Bell's Theorem.
If you want to continue using these terms, you're going to have to give actual definitions of them, and back those definitions up with references. This appears to me to be your personal idiosyncratic terminology. That's not acceptable here.
Reply
