How does matrix non-commutivity relate to eigenvectors?
26 replies · 7K views · last reply
snoopies622
Given matrices A,B and
Condition 1: AB does not equal BA
Condition 2: A and B do not have common eigenvectors
are these two conditions equivalent? If not, exactly how are they related? Since I'm thinking about quantum mechanics I'm wondering specifically about Hermitian matrices, but I'm also curious about how this applies to matrices in general. Thank you!
If in Condition 2, by 'have common eigenvectors', you mean that A and B have exactly the same sets of eigenvectors, with the same multiplicities then I think 1 implies 2 (ie identical eigenvector sets implies the two matrices commute). To see that, just compare the actions of AB and BA on each element of a common eigenbasis. It will be the same.
But I do not think that A and B commuting implies they have the same sets of eigenvectors. Counterexample: ##A=\pmatrix{0&1\\1&0},B=\pmatrix{1&0\\0&2}##. These commute but have different eigenvectors.
Actually for Condition 2 i meant that they have no common eigenvectors at all. So to express the whole thing in contrapositives, let's call
Condition 3: AB=BA
Condition 4: A and B have at least one common eigenvector.
Are these equivalent? (Also, unless I can't do matrix multiplication, I'm getting AB not quite equal to BA for the two matrices in entry #2)
snoopies622 said:
Actually for Condition 2 I meant that they have no common eigenvectors at all. So to express the whole thing in contrapositives, let's call
Condition 3: AB=BA
What about ##A=0## and ##B=1\,##?
Hmm, funny case. It appears to me that both Conditions 3 and 4 are satisfied here, but I'm wondering if they imply one another in every case.
How do they have a common eigenvector? Or do you allow eigenvectors to be equal whereas the eigenvalues are not?
That's what I had in mind, yes. Never thought about these cases before but I guess any vector is an eigenvector of matrix 1 with eigenvalue 1 and likewise any vector is an eigenvector of matrix 0 with eigenvalue 0.
My wondering about this matter springs from quantum mechanics, and specifically what the connection is between non-commuting matrices and the uncertainty principle. Specifically - if two matrices do not commute, does that mean that they have no common eigenvectors? But I would also like a more general and precise understanding of the relationship here between conditions 1 and 2 above (or 3 and 4).
There isn't any direct connection you're looking for. ##[A,B]=0## has at prior nothing to do with eigen vectors. Linear transformations can be split in a semisimple and nilpotent part and there are various theorems about these parts. E.g. for complex vector spaces, semisimple transformations are diagonalizable, and this diagonalization can be done simultaneously for commuting, semisimple transformations.
If you allow any transformations, or not algebraically closed fields, then there can be found counterexamples of all kind. One important remark: A semisimple linear transformation is basically defined by diagonalizability, i.e. pairwise distinct eigenvalues. It has nothing to do, at least not on this level, with the semisimplicity of Lie algebras, may they be defined as matrix algebras or not. However, the classification of semisimple Lie algebras start with Jordan decompositions, i.e. the decomposition of linear transformations in a semisimple and a nilpotent part. An important theorem is: A semisimple, finite dimensional, linear Lie Algebra contains all semisimple and nilpotent parts of its elements. So there are connections between the various concepts, just not as simple as you have thought.
Well that was a much deeper answer that I anticipated, thank you! Here's the section of H.S. Green's "Matrix Mechanics" (1965) that got me thinking.
"A hermitian linear operator (observable) represents a measurable quantity, and its eigenvalues the results of the measurement. If the simultaneous measurement of two different quantities is possible, the observables representing these quantities commute; otherwise, they fail to commute." (p. 34)
So if two matrices A,B representing two different observable quantities have a common eigenvector, then the physical system can be in a state that's an eigenvector for both, and can therefore have a precisely defined value for both physical quantities. If A and B have no common eigenvector, then no such state exists and so the two corresponding physical quantities cannot be simultaneously precisely defined.
Hence a relationship between commutivity, simultaneous observations, and common eigenvectors.
Hermitian is a very strong property. Hermitian matrices are diagonalizable, so two commuting Hermitian matrices are simultaneously diagonalizable, i.e. we can find a basis of eigenvectors in this case.
I am just browsing here but think of your space as decomposed into an orthogonal product of a line and a hyperplane, say L x W. To say the two operators have a common eigenvector, which we may assume lies in L, says nothing at all about the behavior of the two operators on the complementary hyperplane W. I.e. for an operator that preserves orthogonality, if it maps L into itself it also maps W into itself, but that is the only common property of the two operators we seem to have. So this is like asking if we have two operators on LxW that both preserve not only L but also W, then they do have a common eigenvector, namely any ≠0 vector in L, but do they have to have any common properties when restricted to W? Well, no, as long as dim(W) > 1.
So I guess my original question should be as follows: Given hermitian matrices A,B and
Condition 3: AB=BA
Are Conditions 3 and 4 equivalent?
If ##[A,B]=0## then there is even a basis of eigenvectors for both of them and therefore especially at least one eigenvector in common. For the other direction, I think it is not true. I would follow the way @mathwonk has sketched with three or four dimensions and only one eigenvector in common to look for a counterexample. An easy example could be one common eigenvector and the rest some permutation matrices with different signatures (orientation) - but this is only a guess which looks easy to verify.
Condition 3: AB=BA
As far as QM is concerned, no these are not equivalent. If two Hermitian operators commute, then they share a complete set of eigenvectors.
If they do not commute, then they may have common eigenvectors, but not a complete set.
To put it another way, if two operators share a single eigenvector, then they do not necessarily commute. Simple counterexamples can be found as advised by @mathwonk.
Some QM texts may give the impression that non-commuting operators cannot share any common eigenvectors, but that is false.
##\left[\pmatrix{0&1\\1&0},\pmatrix{1&0\\0&2} \right]=\pmatrix{0&1\\-1&0}\neq 0##
If we replace ##2## by ##1## then they commute, are Hermitian, but have both eigenvectors in common.
So in the context of quantum mechanics, suppose matrices A and B do not commute but have a common eigenvector. This implies that - if the system is in the state corresponding to this eigenvector, then it simultaneously has an exact value for both of the physical observables corresponding to A and B, even though A and B do not commute.
Am I correct? This definitely seems to contradict what H.S. Green implies in the quote in entry #9 above.
I think blocked matrices are instructive. Consider the following example:
##\mathbf A := \begin{bmatrix} \mathbf I_m & \mathbf 0\\
\mathbf 0 & \mathbf X_n \end{bmatrix}##
##\mathbf B := \begin{bmatrix} \mathbf I_m & \mathbf 0\\
\mathbf 0 & \mathbf Y_n \end{bmatrix}##
where ##m## and ##n## are positive integers.
If ##\mathbf A## and ##\mathbf B## don't commute (i.e. if ##\mathbf X_n## and ##\mathbf Y_n## don't commute), they still certainly have common eigenvectors -- infact if we like we can say that ##\{\mathbf e_1, \mathbf e_2, ..., \mathbf e_m\}## are all common eigenvectors, and there may be even more.
we can of course also consider things like
##\mathbf A := \begin{bmatrix} \mathbf C_m & \mathbf 0\\
##\mathbf B := \begin{bmatrix} \mathbf C_m & \mathbf 0\\
where ##\mathbf C_m## is a Hermitian -- and still we can say ##\mathbf A## and ##\mathbf B## have at least m common (mutually orthonormal) eigenvectors. From a graph theory standpoint, all I did was put together two disjoint/disconnected graphs into one adjacency matrix, so the result isn't very surprising. But there are lots of other variations that can be done as well.
Thanks all, will pick this up tomorrow after I (hopefully) find a couple very good QM texts from my storage unit. There are some details about the axioms that I'm not remembering exactly and are probably critical here.
d'oh!o:)
So is there a rule in quantum mechanics such that any non-commuting operators (representing physical observables) do not have any common eigenvectors? Otherwise I don't know how to avoid the apparent contradiction I described in entry #16.
There's no contradiction. You may have two observables whose compatibility depends on the state.
Ok, I just want to be clear: You're saying that even within the limited context of quantum mechanics it's possible for two non-commuting operators to have a common eigenvector. Does this not imply that a physical state exists that is an eigenstate of both operators? I thought one way the uncertainty principle is stated is that if two observables are represented by non-commuting operators then no state exists in which both observables simultaneously have exact values.
As this thread has proved, there are operators that do not commute on the whole vector space, but do commute on a subspace.
That translates in QM to a contradiction of your version of the uncertainty principle.
The general uncertainty principle - look it up - involves the expected value of the commutator. That requires a specific state.
However, some operators have a minimum uncertainty across all states.
PeroK I would very much appreciate your thoughts on the essay I linked in entry #20. It's pretty short and the author's thinking seems very close to what brought me here. Thanks.
I would post on the QM forum to see whether anyone has an example of state-dependent uncertainty.
I would be interested in the answer.
Note that there are a lot of Hermitian operators, but most physics is concerned with just a few observables!
Again, it would be interesting to know how many operators are in practical use.
PS spin-1 states are represented by 3d vectors, so you could definitely construct two observables with the "partially" commuting property.
