How does putting batteries in series increase voltage?
Connecting batteries in series increases voltage by adding the electric potential difference of each individual cell. Each battery cell generates a specific voltage, and when combined in series, their voltages accumulate, resulting in a higher total voltage output. The internal chemical reactions within the batteries maintain charge at the terminals when a load is connected, allowing for sustained current flow. Without an external load, the current is momentary as the internal charges reach equilibrium.
  • Understanding of basic electrical concepts, including voltage and current.
  • Familiarity with battery chemistry and galvanic cells.
  • Knowledge of series and parallel circuits.
  • Basic grasp of electrical potential difference.
  • Research the principles of galvanic cells and how they generate voltage.
  • Learn about the chemical reactions occurring in batteries during discharge.
  • Study the differences between series and parallel battery configurations.
  • Explore the concept of internal resistance in batteries and its effects on performance.
Students studying physics or electrical engineering, hobbyists interested in electronics, and anyone seeking to understand battery functionality and voltage generation.
Felchi
When you put batteries you place the negative terminals to the positive which supposedly "bumps' each electron to the next battery. However, the positive terminal is positive enough to neutralize the negative terminal and vice versa. Therefore, when I place batteries in series, only the terminals connected to the load are supplying energy. The other terminals should just be neutralizing one another, yes?
Even if the electrons are bumped along, how does it accumulate more voltage as it travels through the batteries?
Please don't give me overly complicated equations. I'm only in grade 9.
The only possibility I can think of is that the negative terminal has a greater charge than the positive terminal of the battery. In that case you would have electrons being "bumped along" but the number of "bumped" electrons would be (electrons in negative terminal)-(unneutralized protons in positive terminal), which wouldn't be very efficient.
There are no equations needed to explain this:
You're getting hung up on "terminals" in a meaningless way. Just think of eliminating the two terminal that are touching and think of it as having built a bigger battery (that is, more plate, so more volts, not bigger plates so more current).
Just to clarify, how does a battery really work in the first place? That's what's confusing me.
It's called a "battery" because it consists of multiple cells of this type:
http://en.wikipedia.org/wiki/Galvanic_cell
stacked together. Each cell produces a certain electric potential difference, and when the cells are combined in series to form a battery, their potentials add together. Same thing goes for combining two batteries (again, it's just a bunch of individual cells in series).
The amount of charge at the terminals of a battery is relatively small. When there is a load (completed circuit) placed on the battery, the internal chemical reactions will maintain some amount of charge on the terminals corresponding to the voltage versus load for that battery until the battery is depleted.
In the situation where there is no external load and when you first connect the batteries in series, there is a very brief moment where the charge at the terminals results in a tiny amount of current flowing internally within the battery stack, but this only lasts for a brief moment while the internal chemical reactions compensate for a just connected series of batteries. Once a load is placed on the batteries, then the chemical reactions will create and sustain a current flow, and the voltage will equal the sum of the voltage of all the batteries in the series.
Why would the current within the battery stack not be sustained for a long period of time? Does the resistance of an external path somehow offer an incentive for the electrons to travel through it?
If a battery could run forever without getting depleted it would be a perpetual motion machine. Nothing can provide power forever, it's just that batteries run out more quickly than some power sources, such as the sun.
Asuming you mean the case where there is no external load, then the current flows for just a brief moment while charges at the terminals and the chemicals inside reach a point of equlibrium. The charges on the internal terminals is essentially neutral, while the outer terminals retain negative and positive charges.
When a load (completed circuit) is attached to the outer terminals, then the battery stack will maintain the charge corresponding to the voltage versus the load (current) for the outer terminals of the battery stack. The charges on the internal terminals will no longer be neutral, but transition from positive from the positive end of the stack to negative towards the negative end of the stack, again corresponding to the voltage and current flowing through the load and battery stack. During this time the potential energy inside the battery stack is being consumed in the form of a chemical transformation, eventually depleting the battery stack.
So in a battery stack if I were to extract a cell from the middle it would have no charge because it would be neutral?
