How Does Rocket Propulsion Work?
  • Thread starter Thread starter physicsilliterate69
    Physics
21 replies · 4K views · last reply
physicsilliterate69
I have a few questions that I have to have answered by 2-19-05 for a class on the following day. I have tried to solve the problems and have looked in several physics books for help but really have no idea as to the answers. If you can help, I would greatly appreciate it. Again, I am basically physics illiterate (hence the name) so you will need to put your reply in basic terms. Thanks .
There is a rocket. The total momentum is zero relative to the station where the rocket is taking off from. The pilot fires the engine for just a few seconds, converting a mass "Mfuel" from liquid to a gas that shoots off into space behind the ship at a speed "Vfuel." A person at the station sees a flash of gas shoot off to the left and the ship moves to the right.
1. If we know "Mship", "Mfuel", and "Vgas" we can figure out what "Vship" is. let "Mship"=1000kg, "Mfuel"=5kg, and "Vgas"=-5000m/s. What was the ship's speed (V) to the right when it left the dock?
2. A big rocket at launch has a huge ball of flaming gas that is deflected by the ground at the beginning. Does the gas hitting the ground have anything to do with the rocket taking off? Think carefully here--is this really any different than the ship leaving the station--was there anything to "push against" there? Explain.
3. We develop this as a two object system (ship and fuel-gas). How would you explain a rocket ship to another student who has seen a model rocket, bottle rocket or fireworks shot into the air and wonders how that works. Did you ever blow up a balloon and just let it go?
Again, I really need these answers and explinations by 2-19-06. Thanks for any and all help on this.
momentum concepts
Yes, I have the basics. My physics book goes over that part well. My teacher said that these problems have something to do with Newtons 3rd Law...I know that this law has to do with 2 objects (when one object exerts a force on a second object, the second object exerts an equal force int he opposite direction on the first object). Basically, action force and reaction force. I also get the part where the ship is moving in one direction and the gas is moving in the opposite direction. It is the actual setting up the math problem that I am having difficulty with in #1.
For #1 question I have: 1000kg X ? + 5kg X -5000m/s = 0
This is what I get from the problem. I am not sure if this is correct or what to do with it even if it is correct.
Well it sounds like you understand the concepts well enough so it shouldn't be too hard of a problem, you just need to remember that the momentum of the system is always conserved, so if you can figure out what the initial momentum is you can find what the velocity of the rocket afterwards must be in order for the momentum to remain constant.
What is the mathematical definition of momentum? What two things make it up?
momentum = mass X velocity
The problem stated that "at the dock the rocket includes the vehicle and the fuel that will be burned sitting at rest, so the total momentum is zero relative to the station.
Not too sure what this means but I think it is important info otherwise it wouldn't be there?
the momentum before = the momentum afterward soooo,
0 = 0
But I don't know what to do with the other numbers in #1
Ok and what is always true about momentum, it's conserved right? So can you come up with expressions for the total initial and final momentum in terms of the initial and final velocities of the rocket and its fuel?
Conserved, yes. If the object interact with only one another, each object can have its momentum changed in the interaction, provided that the total momentum after it occurs is the same as it was before. The expressions part is where I am lost. I have the basics but the actual setting up of the math problem is where it all goes bad.
Well in the first case since they are one object you can consider the expression
(m_ship + m_fuel)v_shipandfuel = 0 because they are just sitting on the platform.
Can you figure out what the case has to be after they start moving in oppsoite directions?
Okay...I might have something.
m_fuel = 5kg
v_gas= -5000m/s
m_ship= 1000kg
5kg x -5000m/s divided by 1000kg
= -25000 divided by 1000
= -25
Am I totally off base or at least in the ballpark??
m_ship = 1000kg + m_fuel = 5kg = 1005kg
I don't know how to get the v_ship and fuel number
When they begin to move in opposite directions one is a positive number and the other is a negative number so they cancell each other out to equal zero.
m_fuel = 5kg
v_gas= -5000m/s
m_ship= 1000kg
= -25
You're really close you just need to remember that momentum is a vector and direction matters they both can't have negative velocity otherwise the momentum wouldn't be conserved.
you have something along the lines of
let m = mass of fuel
let M = mass of rocket
let v = velocity of fuel
and let V = velocity of the rocket.
Now since momentum is conserved and we know that the initial momentum was zero we know that
0 = mv + MV this is just a statement that momentum is conserved in this system.
You know m, M, and v so you can find V.
That was just an example of an expression for the initial momentum, which is obviously zero since neither object is moving thus the velocity must have been 0.
5kg (-5000m/s) + 1000kg (V)
-25000 + ??
I cannot figure out how to find Velocity or rocket. I keep thinking to divide the -25000 by 1000 to get an answer of -25 but this still seems wrong
-25000 + ??
I already gave you the equation which you have to use, you can't solve for anything the way you wrote it, you need to have an equation.
how about 5kg(-5000m/s) + 1000kg(25) = 0
? Maybe?
? Maybe?
Yes, you see you can't get anything from saying
mv + MV
you have to say
mv + MV = 0
Yes the answer should be 25m/s.
Oh my gosh...I actually did it...thank you sooo much! Lightbulb moment! It finally makes sense to me!
I have been working on this for hours. Now that this first part is done I have to take a break and get some shut eye. Thanks again. I might be online again tomorrow morning or Sunday evening for more help on the other questions.
