How Does SATA 3.0 Compare to SATA 2.0 in Performance for a Desktop Workstation?
  • Thread starter dillonjerry
In summary: GB drive), and have the second partition on the second drive as your "home" or "system" partition. But you wouldn't be able to use the second drive for anything else.The 10,000 rpm drives will have a faster average seek time. the streaming transfer rate might be better on the 7,200 rpm drives if those are based on newer tehcnology with sufficiently higher bit densities to compensate for the slower rotation rate.
dillonjerry
So I'm building a new workstation right now, and by no means is this the first time. The board is an ASUS P8P67, and the CPU is an Intel 2500k. I plan on running the OS off of a RAID0 array. I image my OS partition on a regular basis, so I'm not worried about being in RAID0. My question is this. I can either go with two WD 74 Gb VelociRaptors or two Segate 500 Gb drives. Normally this would be a no brainer, I'd go with the 10k drives. But the WD drives are ATA/300, while the Segate drives are ATA/600. How will these two drives compare in performance? Does SATA 3.0 have as much an impact as a SATA 2.0 drive running at 10k RPM's?
This is a desktop workstation, I'm not concerned about gaming. Much more concerned with CAD and applications. Any thoughts?
Computer science news on Phys.org
Check out the maximum burst read speeds for the hard drive. If it's lower than SATA2's 375MB/s capabilities, I wouldn't bother with SATA 3 worries. And I highly highly doubt it's even 150MB/s burst.
Sata 2 transfer rates exceed the streaming rates of any current hard drive.
There are also SSD (solid state) drives from 40GB to 600GB, but I'm not sure of the streaming rate versus the latest drives, probably the Seagate XT 2GB hard drives, with max rates over 100 mega-bytes per second.
You may be able to use a utlity to "destroke" (usually a mode select command) a hard drive, reducing it's capacity by only using the outer diameter (faster streaming rate).
I've heard that there were ways to structure the data on the platters that would result in faster seek times. I was under the impression that the inner region was the fastest, but I could be wrong. I've never heard of being able to actually limit the locations on the platters where data is written to. What utility would you use to do this?
You'd have to contact the hard drive maker to see if a uitlity exists for a particular drive. I think that companies that buy a lot of drives for raid arrays are able to either order destroked drives (set up drive maker) or to get utilities to destroke (short stroke) the drives themselves.
Wouldn't limiting the partition size be essentially the same thing? I mean, if is a 500GB drive, and you set up a partition that's only 100GB, wouldn't this be similar? The only difference being that maybe you wouldn't have control over where the data is being stored on the platters themselves?
Solid state drives are hitting in excess of 300MB/s read speeds these days. WOOT.
You'd need to restrict the partition size so it only occupied the outer diameter of the first platter surface. Most current technology drives have 500GB to 600GB per platter (2 surfaces), so a 500GB current technology drive should be a single platter drive with 2 surfaces. You do need to check the specifications. I found that Best Buy is still selling older tech Seagate 7200.9 drives (current tech drives are 7200.12). I don't know what the capacity per platter is on the 7200.9 drives, but the bit density and streaming data rates are slower.
This document from Seagate mentions using mode select to destroke drives, but doesn't mention where to get the utlity that does this. I'm guessing that raid controllers (ones you plug into a PCI or PCI Express slot) come with software utilities to do this.
http://www.seagate.com/docs/pdf/en-GB/whitepaper/mb603_1_high_capacity_storage_readiness.pdf
For a home user, since the first partition will end up on the outer diameter of the first surface, you can keep the first partition on each drive relatively small (100GB would use a bit less than 1/2 of the 250GB per surface).
Related to How Does SATA 3.0 Compare to SATA 2.0 in Performance for a Desktop Workstation?
1. What is the difference between VRaptor SATA2.0 and SATA3.0?
SATA2.0 and SATA3.0 are both versions of the Serial ATA (SATA) interface used for connecting storage devices, such as hard drives, to a computer. The main difference between the two is the maximum data transfer rate. SATA2.0 has a maximum transfer rate of 3 Gb/s, while SATA3.0 has a maximum transfer rate of 6 Gb/s. This means that SATA3.0 is capable of transferring data at twice the speed of SATA2.0.
2. Which one is better for gaming, VRaptor SATA2.0 or SATA3.0?
SATA3.0 is generally considered better for gaming because of its faster data transfer rate. This means that game load times will be shorter and game performance may be improved. However, the difference may not be noticeable in all games, and other factors such as the speed of the processor and graphics card also play a role in gaming performance.
3. Can I use a SATA2.0 device with a SATA3.0 interface?
Yes, you can use a SATA2.0 device with a SATA3.0 interface. SATA3.0 is backwards compatible with SATA2.0, so you will still be able to use the device, but at the slower SATA2.0 speed. Keep in mind that if you are using a SATA3.0 device with a SATA2.0 interface, it will also run at the slower SATA2.0 speed.
4. Are there any other differences between VRaptor SATA2.0 and SATA3.0?
In addition to the data transfer rate, there are a few other differences between SATA2.0 and SATA3.0. SATA3.0 uses a different signaling method than SATA2.0, which allows for better data integrity and error correction. SATA3.0 also has improved power management capabilities, allowing for more efficient power usage. These differences may not be noticeable to the average user, but can be beneficial for certain applications.
5. Is there a significant price difference between VRaptor SATA2.0 and SATA3.0?
The price difference between SATA2.0 and SATA3.0 can vary depending on the specific device and manufacturer. In general, SATA3.0 devices may be slightly more expensive than SATA2.0 devices, but the price difference is not usually significant. The cost difference may be worth it for those who require faster data transfer speeds, such as for gaming or video editing, but for general use, SATA2.0 may be a more cost-effective option.
