How does speed change when centripetal force and radius both double?
brake4country
The centripetal force acting on an object is doubled. The radius is also doubled. The speed of the object:
(a) increases by a factor of 4
(b) increases by a factor of 2
(c) decreases by a factor of 2
(d) The change in the object's speed depends on its mass
F = mv2/r
So if I substitute 2's in for F and r in the above equation, my 2's cancel but the correct answer is a. ?
Not happy with the wording of the question. Centripetal force does not act. It is the force required to be supplied by forces which do act in order to produce a certain motion.
Anyway, I don't get how the 2's would cancel. (Not that I necessarily agree with the supposed answer.). Please post detailed working.
I am sorry; an erroneous math calculation. By substituting 2 for both the force and the radius, I get 4 which is (a). Thank you!
Can you still show your calculation ? It doesn't fit at all.
As I hinted, I disagree with that answer. Looks like BvU disagrees with it too.
Sorry everyone! That's what happens when you don't read the answer choices correctly! Okay here is the original question: the centripetal force acting on an object is doubled. The radius of the object's motion is also doubled. The speed of the object is:
(A) increases by a factor of
(B) increases by a factor of 2
(C) decreases by a factor of 2
(D) the change in the object's speed depends on its mass.
Fc = mv2/r. If I plug in 2 for F and r, I get 2 = mv2/2 = 4 = mv2. Therefore, the correct answer is (B) increases by a factor of 2! Thanks everyone!
