How Does Temperature Affect Water Overflow and Gas Behavior in Physics Problems?
  • Thread starter Thread starter Kickbladesama
1 reply · 3K views
Kickbladesama
need help on three problems fast!
A cylindrical brass container with a base of 87.0 cm2 and height of 20.0 cm is filled to the brim with water when the system is at 25.0°C. How much water overflows when the temperature of the water and the container is raised to 94.5°C? (The coefficient of volume expansion for water and brass are 207 multiplied by 10-6 K-1 and 57 multiplied by 10-6 K-1, respectively.)
At 0.0°C and 1.00 atm, 0.95 mol of a gas occupies a volume of 0.0213 m3.
(a) What is the number density?
(b) Estimate the average distance between the gas molecules.
(c) If the gas is composed of diatomic molecules with a molecular mass of 29.16500 g/mol, what is the total mass?
(d)What is the mass density?
A sealed cylinder contains a sample of ideal gas at a pressure of 1.1 atm. The rms speed of the molecules is v0. If the rms speed is then reduced to 0.73v0, what is the pressure of the gas?
pV = NRT
deltaL/L = alpha x temp
Hi Kickbladesama!
Show us what you've tried, and where you're stuck, and then we'll know how to help. :smile:
