How Does the Angle of Deviation Depend on the Angle Between Two Mirrors?
The original poster is exploring the relationship between the angle of deviation of a light ray and the angle between two mirrors. The problem involves understanding how light reflects off mirrors and how to calculate the angle of deviation in different configurations of mirrors.
  • The original poster attempts to understand the concept of angle of deviation in the context of two mirrors, questioning how to calculate it based on the angles involved. They present diagrams to illustrate their confusion regarding the angles of incidence and reflection.
  • Some participants clarify the definition of angle of deviation and discuss its application to multiple mirrors, while others express uncertainty about how to apply the concept to the specific case of two mirrors.
Participants are actively engaging with the original poster's questions, providing insights into the definition of angle of deviation and its calculation. There is a mix of interpretations regarding the angle of deviation in different scenarios, with some participants suggesting that it cannot exceed 180 degrees. The discussion is ongoing, with no explicit consensus reached yet.
The original poster mentions a lack of guidance from their teacher, which may contribute to the uncertainty in their understanding of the problem. There are also references to specific angles and configurations that are under discussion, indicating a need for clarity on how these relate to the angle of deviation.
XigmaTek
Hi, my teacher asked me to conduct an experiment on the question "How does the angle of deviation depend upon the angle between two mirrors?" - We weren't given much else on the topic. I know how to find the angle between two mirrors, but finding the angle of deviation of the light ray is what I'm lost at.
Law of Reflection?
I came up with my own solutions to try and find a method to calculate angle of deviation. Anyway, here is the diagram which I created to hopefully shed some light on the situation
[PLAIN]http://img696.imageshack.us/img696/6097/phys1k.jpg
As you can see, θi is the incoming light ray (just a name for it...) and θf is the final, or outgoing ray. Now, as seen, θf (the outgoing ray) has been reflected straight back in the same direction as the original ray. Do I just say the angle of deviation is 360, or does it have something to do with the angles made at the mirrors (m1 and M2). θ1+θ2 = 180, so is that the angle of deviation?
___________________________
Now in the image below (which I again made, myself), if you only adjust one of the mirrors (I changed M2), you get a different story. Now, as seen the outgoing light ray continues on in the same direction as the incoming light ray. Is the Angle of Deviation Zero degrees here? Or do I add up the angles between M1 and M2? Which gives me 180? But how can the Angle of Deviation be 180 when the light ray simply keeps going on in the same direction?
[PLAIN]http://img404.imageshack.us/img404/7955/phys2.jpg
I'm lost as to how to find the Angle of Deviation of a light ray after reflection of 2 mirrors...
Please help. Thanks !
A ray of light that is incident on to the surface of a plane-mirror is reflected with the angle of incidence equal to the angle of reflection. Suppose that the ray had continued, through the mirror, in a straight line it would make an angle θ with the surface of the mirror. The total angle between the straight-line path and the reflected ray is twice the angle of incidence. This is called the deviation of the light and measures the angle at which the light has strayed from its initial straight-line path.
http://www.splung.com/content/sid/4/page/planemirrors
If that's the case then, how do I apply that to 2 mirrors? I understand that concept for 1 mirror... But how to apply it to 2, I'm lost.
Angle of deviation is the angle of reflected ray with respect to the incident ray. It is nothing to do with the number of the mirrors and their arrangement in between.
Now you can find out the result.
So with my first image posted up, if I compare the reflected ray to the incoming ray, Is the angle of deviation 360*? and for the second image is just simply zero*?
In the first case the angle of deviation is 180*. It can't be more than 180*. The ray of light is not a rotating vector.
Thanks mr. Rajrendra Lakshmanapathy Bhat... your help has been great. So, from this, I take it you just compare the two angles together (incident & final-reflected rays) and see the angle made between them... So for my second image, the Angle of Deviation is 0*, right? Again, thanks for the help mate
17K
20K
