How Does Unity Position Feedback Affect System Dynamics in Control Theory?
94 replies · 14K views
I keep getting the same result, therefore I don't think it's a mistake in my multiplication when working out my tf. It must be the position of the pole.
  • To work out the position of the pole, I just used trig. Knowing the 3 angles (1.58, 88.42 & 90) & the height of the right angled tri i.e. 2.0 ,to put pole on real axis. I then derived the length of the base (base equal to 72.54). The reference pole was at (-1) on real axis therefore my new pole is at -73.51?
  • I'm really not sure what's wrong with the method or calc?
I had another look at your root locus plot. I can't tell exactly what it is you're doing, but it shows a zero at -73.51, not a pole (circles are zeros, crosses are poles).
You can include your MATLAB code using [ code ][ /code ] tags without the spaces.
So with the addition of the compensator pole, does the root locus now pass through ##s = -1 \pm j2##?
No it's close but it doesn't go through these ponts?
If I use your pole location, I have it passing through within ##s = (-1 \pm 0.005) \pm j(2 \pm 0.005)##. That's close enough.
Now you need the value of ##K_1## that places closed-loop poles at that location.
Yes you're right it does. I was looking at the wrong root locus (I now have several on my desktop). So K1 representing the gain, I need to find a value for it that places 'closed loop' poles at s = -1 +/- 2j. I was getting confused with the open/closed loop. I plot the locus with open loop tf but it shows the possible positions of closed loop poles.
  • To find the value of K1, is there a formula or would I just move the 'pink dot' until its in the required position & read off the value?
When you say that it comes as close as 0.005, is this on the root locus with the compensator added? When I zoom in it looks as if it's way further out. Am I even looking at the correct plot?
rlocus plot: https://app.box.com/s/0w8pszlnpxa31vxpn0an
Th
I've run this through numerous times & the open-loop tf I'm using has all the necessary poles & zeros:
  • Poles: s = -73.51, -2, -1.25, -0.117 ± 0.0511j
  • Zeros: s = -1.58, -0.452
But looking at the root locus plot, none of the branches intersect with s = -1 ± 2j. The closest branch is at least 0.3 out. I'm unsure as to where our methods diverged? I don't see a way to find K1 if there's no intersection. Any instruction on this last bit would be appreciated...
toolpusher123 said:
Finally got the root locus to come out correctly:D. I'd been using wxMaxima to multiply out my tf's so I could get them in a format that I'm familiar with inputting into MATLAB. But wxMaxima seems to be giving an incorrect result. When I did it by hand, the root locus passed through s = -1+/- 2j. There's a plot below:
Root Locus + Compensator: https://app.box.com/s/stheyn866bi43dez9rxe
I think you're making things more difficult than they need be, and in the process, you're including some errors. Let MATLAB handle some of the difficult bits, so it's easier for you to check your results.
As an example, here's how I would plot the root locus with your compensator added:
Code:
s = tf('s');
G = -0.125*(s + 0.452)/((s + 1.25)*(s^2 + 0.234*s + 0.0163));
P = -2/(s + 2)*G;
C = (s + 1)/(s + 73.51);
rlocus(C*P)
Tip: You can click the root locus to add a draggable point on it that shows numerical values.
There is an intersection, and to find ##K_1##, consider that the characteristic equation for your system is true for any point that's on the root locus. If you plug your numbers into this equation, how many unknowns are there?
I get the exact same plot as I did before, with no intesection at s = -1 =/- 2j ? In the example above for C, it shows the zero as s = -1 ? Is this the value I should be using, as I've been using s = 1.58 ?
If I use the s=-1, then I get a plot that quite similar but with the intersection at s= -1+/- 2j.
Edit: Yes we were given the zero at -1. Somehow I thought we'd derived a new one at s = -1.58??
Spent the whole night chasing my tail, when it was in black & white all along!
When I produce the 'step' response, the overshoot is gone but it still has a settling time of 36 secs. How would I go about reducing it to the design specs?
Are there any purple/pink dots at ##s = -1 \pm j2##? What does that mean?
No. Are these markers of the gain (K)? I've tried to move them in order to adjust the reponse but it just becomes totally unstable?
Edit: moving the 'pink dot' to -1+/- 2j I've reduced the Ts to under 4 secs but the PO is 22.6%. Does this mean I would have to use the same process again to get closer to design specs?
It won't be exact, since you're not working with a true second-order system. Try moving the compensator zero to -0.5 and recalculate your controller (including ##K_1##).
The "fix" I mentioned, is to try and make sure there are zeros near the conjugate pair of closed-loop poles that's closer to the imaginary axis than ##s = -1 \pm j2##. It's an effort to get them to cancel, so you won't have their effect in the system.
One last thing I was going to ask, as I've asked you countless questions so far. Is for Q6,7 I've got to repeat the earlier Q's i.e plot root locus & do the 2nd order approx. This time I include (-K2s). I've been trying to resolve the TF I should use. Till now it's been 'open-loop',
  • Would I find the closed loop for; (2/s+2) * Gs)/1+(2/s+2)*Gs*(-k2s) & then multiply by -k1?
  • 40(250s+113)/(40000s^4+139360s^3+141072s^2+30039s+1630)
No, it's good thinking, but that would only be correct if ##K_2## was a constant. You're asked to set ##K_2 = K_1##, and ##K_1## is the parameter you want to plot the root locus for as it varies.
In a nutshell: You need the characteristic equation for your system to have the form:
1 + K F(s) = 0 \quad (1)
where ##K## is the parameter you want to plot the root locus for, and ##F(s)## is not a function of ##K##.
As an example, consider the characteristic equation for your system without the velocity feedback:
1 - K_1 \frac{2}{s + 2} G(s) = 0 \Leftrightarrow 1 - K_1 F(s) = 0, F(s) = \frac{2}{s + 2} G(s)
All is well, since ##F(s)## isn't a function of ##K_1##.
In short: You need to put the characteristic equation for your system with velocity feedback into the form ##(1)##. ##F(s)## is then the function you need to use with 'rlocus' etc. in MATLAB.
Correction: Should be:
1 - K_1 \frac{2}{s + 2} G(s) = 0 \Leftrightarrow 1 + K_1 F(s) = 0, F(s) = -\frac{2}{s + 2} G(s)
I dun goofed there.
Does the above represent the 'open loop' tf when the system includes K1 & K2?
If by above you mean post #81, then no. It was just a correction to post #80.
Again:
Therefore F(s) = 2/(s+2)*G(s)
No, ##F(s) = -\frac{2}{s + 2} G(s)## for the system without velocity feedback.
You need to figure out what the characteristic equation is for your system when you add the inner feedback loop.
But that's exactly where I'm stuck, I've done everything but I'm not sure how to get the 'open loop' with velocity feedback i.e. K1=K2. For the 1st system you just multiply :
  • -1*2/(s+2)*G(s)
  • But how do you work out the open loop tf with velocity feedback? Not sure how to deal with the closed loop part with K2
  • Would it be: 1+Ks(s)G(s)(2/(s+2))?
I'm all for helping, but you have to start showing more of your thought process behind your work. Right now, it just looks like you're guessing.
If you've studied feedback systems in some form, lectures/textbook etc., you should know what the characteristic equation is for such a system, e.g.:
What is the characteristic equation for this system?
-K1*H(s)*(G(s)/1-H(s)*G(s)*K2s ?
  • H(s) = 2/(s+2)
  • G(s) = -0.125(s+0.452)/(s+1.25)(s^2+0.234s+0.0163)
  • Therefore as I originally said , find closed loop of H(s), G(s) & -k2s
  • the open loop is then: the closed loop above * -k1
  • Root Locus Plot:
  • Open Loop Bode Plot: https://app.box.com/s/iaqcgq70apqf6v2staw5
The picture has nothing to do with the system in your assignment.
In terms of the functions ##G(s)## and ##H(s)##, what is the characteristic equation for the system in the picture?
