How far along circular arch is an astronaut
  • Thread starter Thread starter sweetwilliam
    Astronaut Circular
The discussion revolves around calculating the distance an astronaut in chamber B travels along a circular arc when an astronaut in chamber A moves 240 meters. Given the radii of the chambers, r(A) = 320 meters and r(B) = 1100 meters, the relationship between the distances can be established using the formula for arc length, s = θ × r. The correct approach involves using the proportion of the radii to determine the arc length for chamber B, confirming that both chambers share the same angle θ during the rotation.
  • Understanding of circular motion and arc length
  • Familiarity with the formula for arc length: s = θ × r
  • Basic knowledge of proportions in geometry
  • Concept of angular displacement in rotational motion
  • Study the derivation and applications of the arc length formula in circular motion
  • Explore the relationship between linear and angular velocity in rotational dynamics
  • Learn about the principles of rotational kinematics and dynamics
  • Investigate the effects of radius on the motion of objects in circular paths
Students studying physics, particularly those focusing on circular motion and dynamics, as well as educators seeking to clarify concepts related to arc length and proportional reasoning in rotational systems.
sweetwilliam
a space station consists of two donut shaped living chambers A and B, that have radii r(A)= 3.2x10^2m and r(B)=1.10x10^3m. As the station rotates, the astronaut in chamber A is moved 2.40x10^2 m along a circular arc. how far along a circular arc is an astronaut in chamber B moved during the same time?
i used a proportion r(A)/ circular arc = r(B)/ x and solved for x i got the correct answer but my
but i was wondering if there was a different way to solve this using formulas...my physics prof. would not be happy if i didnt use correct formulas. thanks!
Do you remember the formula for arc length? Find θ, it will be the same for both living chambers. Do you see why your approach also works using the arc length formula?
s=theta x r i see now how that works...thanks so much, i didnt think of that at first. thanks
  • · Replies 22 ·
