How far does light from a 1 candela source remain detectable?
  • Level: Undergrad
  • Thread starter Thread starter zeromodz
    Luminosity
47 replies · 9K views
zeromodz
Like say I have one candela of luminosity. How far away do I have to go until the photons of this light are completely undetectable?
Given a PERFECT detector with ZERO noise or interference, there isn't a maximum distance. As long as one photon from the candle hits it, it would detect it. The further away you go the less photons per unit of time will hit the detector.
In real life it's like Andy said. You will reach a point where you cannot detect it with your detector due to sensetivity and noise and such.
russ_watters said:
...which is only a matter of waiting long enough.
Yep, just like I said. =)
Given it travels as a wave how can it be in so many places at the same time, before it is detected?
Light travels in "packets of energy" called Photons, the particle of light. The light bulbs you see everywhere emit trillions upon trillions of photons per second. Only when a photon hits the right point in your eye can you see it, even though many many more are actually entering it.
ALL matter AND light has wavelike and particlelike properties. You'd have to look up more about Quantum Physics to learn about it all.
But the double slit experiment says it travels as a wave, and not like a particle, thus it must (the wave) be in all directions at once.
russ_watters said:
The double slit experiment is more complicated than that. Light may show similarities to a wave but it is not a wave.
Not sure what your point is, however it does travel like a wave and a wave moves in all directions at once.
I think light is a wave and not a particle at all.
Define "detect."
For example, if at noon you are looking at a star in the sky, you will be getting photons from that star hitting your eye. Unfortunately, you won't be able to notice that star because it will get lost the noise of the sun.
AtomicJoe said:
...and a wave moves in all directions at once...
Where did you get that idea?
A "pressure" wave can be made to do this, but not a singular photon wave.
There is an answer in terms of classical information theory. Given a narrow enough bandwidth (enough time) then you can detect a signal in any arbitratry amount of noise and interference (sunlight and other light pollution).
However, once you get down to energy flux densities so low that you need to consider individual photons (not necessarily little bullet-type particles but quanta of Energy) you are in the realms of probability and statistics. But, still, there is no real lower limit.
I believe our eyes, when fully dark adapted and in 'pitch dark' conditions can be shown to detect individual photons and, of course, photomultipliers can, too.
Extending this to the "how far away can I go?" question, however, implies doing it in the open - when light interference would come into play. Designing a telescope with zero flare is hard / impossible so you can't eliminate stray light completely.
Like Russ said, that is incorrect. There is overwhelming evidence that light has properties of BOTH waves and particles. Look up the photoelectric effect.
Heck, you can stick with the double-slit experiment. It can be performed by firing one photon at a time at the slits. When most people find out what happens for the first time, it blows their minds!
Yes, but that still demonstrates the wavelike properties of the photon. The photoelectric effect is one of the most basic demonstrations of the particle like properties of the photon, as Einstein himself explained!
russ_watters said:
Well sorry, but both of those statements are just plain factually wrong.
The statements.
s1) Not sure what your point is, however it does travel like a wave and a wave moves in all directions at once.
s2) I think light is a wave and not a particle at all.
For s1 the double slit experiment shows it travels as wave does it not?
As for s2, well I am entitled to be wrong in my thinking I guess, but I find it easier to think of a particle as a special type of wave rather than accept a particle went through two slits at the same time. So if I was forced to choose I go for a wave. Maybe the answer is that is is 'something else'.
Well I looked it up but I am slightly confused as to what I should be looking for.
Definition/Summary
When a metal surface is irradiated, it ejects electrons whose kinetic energy can be measured. This electron emission only happens when the irradiating light is above a certain angular frequency . This frequency threshold is found to be independent of the intensity of the radiation. The kinetic energy of the electrons is found to be linearly related to the frequency of light after the threshold, with
OK you say this is a demonstration of the particle properties, however looking at the highlighted text in bold, isn't it evidence of wave like properties?
After-all, particles do not have frequencies!
1. Light has some similarities to waves, but, also behaves in distinctly unwavelike ways.
2. A wave - any wave - does not need to move in all directions at once.
Absolutely not.
Yes, you are certainly entitled to be wrong if you want, but given a choice, I'd think you'd want to be right! That's why most people come here, after all - to learn what is right.
The answer to how light travels is, in fact, "something else" besides a (classical) particle and a wave. Light travels in photons, which have properties like waves and particles, but are not either. They are "something else".
Particles do have frequencies, but that's besides the point. The point is that a single photon knocks-loose a single electron, demonstrating clearly that light is quantized (travels in discrete packets).
In the double-slit experiment, it is possible to fire single photons at a time and watch them impact a single spot on a detector, also clearly demonstrating a particle-like behavior.
AtomicJoe said:
The statements.
1. It demonstrates the wavelike properties of the photon, yes. But you cannot look SOLELY at that one experiment. You must look at all of the available evidence.
2. You can think what you like. Just realize that when you tell people that they will most likely say that you are wrong because the available evidence supports them.
3. Light, and all matter as well, is neither a particle NOR a wave only. It all has properties of both. You don't have to "choose" one or the other.
Didn't the double slit experiment show that light must behave as both a particle and a wave for it to make the observed interference pattern? Like it behaves as one of them when it passes through one slit, then it behaves as the other when it passes through the other slit.
Not quite. The double slit experiment shows that even when a SINGLE photon is fired at TWO slits, it interferes with itself and produces and interference pattern after a large number of single photons are detected over time and the pattern is observed.
You would THINK that the photon would have to go through one slit OR the other. But that is incorrect. Also, with a single photon at a time going through the slits, you would think that it would be impossible for it to interfere, since there aren't any other photons to interfere with. However it has been shown that the photon will interfere with itself.
Ah, the slits are side-by-side not one after the other. Right.
Now that you've jogged my memory, I think I read it like this: A single photon behaving as wave goes through both slits and interferes with itself, but when it hits the detection plate (made of silver?) it behaves as a particle.
The culiminative effect of photons over time contribute to the pattern observed.
Yes - the photons might individually land anywhere, but as you watch large numbers over time, you find they follow the probability distribution of the interference pattern.
russ_watters said:
. Particles do have frequencies, but that's besides the point. The point is that a single photon knocks-loose a single electron, demonstrating clearly that light is quantized (travels in discrete packets).
Well waves definitely have frequencies (too), I am not to happy about particles having frequencies, however that is rather irrelevant to the point.
The point is, demonstrating 'it' has a frequency does not seem to prove much really does it as that is a property possessed by both waves, and particles.
It like saying, which man committed the murder, of the one in the blue hat, well both men have blue hats!
Then we get to the point that a single electron is released, well I can say the wave had enough energy to release a particle can't I?
The shorter the wavelength, the more it behaves as a particle.
Dim UV can knock off electrons from metals, but blinding red light carrying the same energy or more cannot.
If it were a totally classical wave, it wouldn't matter whether the energy was carried as frequency or amplitude. The fact that it does matter, suggests a particle nature.
I don't see that, turning up the light just means more waves are emitted per second, so to me it proves nothing.
Except that like Dr Lots o watts said, a huge amount of deep red light cannot eject electrons, while a single photon of UV light can.
Also, electrons ALSO behave like particles and waves. How would you explain that?
