How far will a piece from an explosive projectile fly?
  • Thread starter Thread starter songoku
    Projectile
The discussion revolves around calculating how far a piece from an explosive projectile will fly after it explodes at its highest point. Participants debate the applicability of conservation of momentum and energy, with a focus on whether the system can be considered closed despite external forces like gravity. It is suggested that horizontal momentum is conserved, allowing for the determination of the horizontal distance traveled by the fragments. The center of mass of the system is also discussed, with the consensus that it will move horizontally at a constant velocity, leading to a conclusion about where the center of mass lands. Ultimately, the problem is framed as a simplified homework question, emphasizing the need for assumptions about initial velocities to arrive at a solution.
songoku
A projectile is fired from a cannon at position X. At its highest point, it explodes into two equal parts. One of the parts falls vertically (as shown in the figure) and lands at distance of 1000 m from X. How far (horizontally) will the second part land from X?
a. 1000 m
b. 1500 m
c. 2000 m
d. 2500 m
e. 3000 m
Conservation of momentum
At first, I want to use conservation of momentum when the object explodes at the highest position but I think the projectile is not a closed system (there is weight acting on it). Tried conservation of energy but not enough information provided.
What approach should I take for this question?
Thanks
I suspect you are overthinking it. It might make more sense to think of this problem on a billiards table; I'm pretty sure you can ignore the vertical component.
Likes songoku and hutchphd
Do you mean I can use conservation of momentum at the highest point, even though there is net external force acting on the projectile?
Thanks
Likes hutchphd
I would break the problem into two pieces. What are the conditions (exact velocities of the two pieces) immediately after the explosion? The result should then be evident.
Likes songoku
Horizontal momentum is conserved because there are no horizontal external forces. Can you show that the two pieces take the same amount of time to reach the ground? If so, then where does the center of mass land?
Likes songoku
There is no vertical component to the separation, if for no other reason than that answer isn't one of the ones listed.
It does say that is the highest point reached (presumably by either fragment ...)
Likes songoku
I think I get the result. Since the horizontal momentum is conserved, the second part of the projectile will move to the right because the other part of the projectile undergoes vertical motion with zero initial velocity.
Using conservation of momentum, the speed of the second part of the projectile is twice the initial speed of the projectile before explosion (because the mass is half of initial) so the horizontal distance traveled will also be twice (measured from highest position)
I get the answer is (e)
Yes
Sorry I don't understand this part. Do you mean the center of mass of the two parts of projectile after explosion? Wouldn't it be in the middle of the two fragments?
Thanks
What does conservation of linear momentum have to say about the motion of the center of mass when collisions (or explosions) occur? If the projectile did not explode, would it land at a different point from that of the center of mass of the exploded projectile?
Likes songoku and DaveC426913
Ah. This clicked it for me. Once you determine the motion of the CoM, the correct answer follows intuitively.
Elegant solution.
But one does not know with certainty that this explosion did not impart net momentum to the center of mass of the fragments. The explosive gases leave the system and so this it not obviously true...I believe this is what is rightfully worrying the OP. The intent of the question wants this assumption but it could be more clearly formulated (maybe using an internal spring?)
Yes, one could be more realistic and start worrying that gases from the explosion carry some of the momentum way. However, the statement of the problem says about the projectile, "At its highest point, it explodes into two equal parts." I think that "equal parts" leaves no room for gases and makes the intent of the problem's author obvious.
Elegant solution.
But it is important to ascertain that the two pieces land at the same time before this solution is applied as is. If, say, the vertically falling piece lands first, one needs to take into account that the CoM keeps moving horizontally until the second piece lands. I remember seeing a problem where this was the case with the second piece going over a cliff.
Likes nasu
kuruman said:
But it is important to ascertain that the two pieces land at the same time for this solution to work. If the vertically falling piece lands first, one needs to take into account that the CoM keeps moving horizontally until the second piece lands. I remember seeing a problem where this was the case.
True, but I'd say that's outside the scope of this question since no such data is provided or implicit.
In its defense, it does say "one part falls vertically", which could give one license to assume initial vertical velocity of zero.
I agree 100% with what you say, as this is not a rocket science problem :oldsmile:. However, if I were to pick nits, I would say that an object released from rest from a height is "falling vertically" throughout its motion until it stops. "Falling vertically" only establishes that the object has no instantaneous horizontal velocity component and says nothing about the initial vertical component.
A clearer way to formulate the question could have been, "Immediately after the explosion, one of the parts drops vertically while the other part moves horizontally. The first part (as shown in the figure) lands at distance of 1000 m from X. How far (horizontally) will the second part land from X?"
Likes songoku
The center of mass will move with constant velocity in horizontal direction since no net external force acting on it.
If the projectile did not explode, it would land at same point of the center of mass of exploded projectile.
The center of mass will land at distance 2000 m from X so the second part of exploded projectile should land at distance 3000 m from X.
Is this what you mean?
Thanks
I think we must assume the vertically falling part to have an initial downward velocity (##\ne 0##) since in any explosion parts fly off with certain non-zero velocities due to the explosive forces acting on exploded parts being extremely high in magnitude.
Likes songoku
songoku said:
Homework Statement:: A projectile is fired from a cannon at position X. At its highest point, it explodes into two equal parts. One of the parts falls vertically (as shown in the figure) and lands at distance of 1000 m from X. How far (horizontally) will the second part land from X?
a. 1000 m
b. 1500 m
c. 2000 m
d. 2500 m
e. 3000 m
Relevant Equations:: Conservation of momentum
Conservation of momentum always applies to an explosion if you consider the just before explosion momentum and just after explosion momentum.
This is inspite of the external gravitational force acting on the exploding mass because explosive forces are huge in magnitude compared to gravitational force in typical cases. With above assumption, it means that only internal explosive forces act on exploded parts and there is no external force. With no external force acting, we can therefore say that momentum gets conserved during an explosion.
Likes songoku
That might be the case in real life, but this is a deliberately simplified homework question, and:
  1. we have to assume we are given all the values necessary to solve it.
  2. if we were to grant your assumption, then the problem is unsolvable, since we are not given sufficient information.
Likes songoku and vcsharp2003
It is solvable. I have done it before posting my thoughts.
We simply start with all unkowns like ##u## as initial projected velocity at ##\theta## with ground. We also assume that second part after explosion fires of at ##v_2## at ##\alpha## angle with horizontal. The first part fires off at ##v_1## in a vertically downward direction.
Then we simply apply law of conservation of momentum to explosion and also the horizontal range formula to projectile.
It will all finally work out. I can show the complete solution, but it's prohibited in this forum to show full solution. I can give more hints if you want to solve this problem using these unknowns.
EDIT: I found even my solution was using an implicit assumption as explained in my post#23. So, without making some assumption, you're right about the problem being unsolvable.
Likes songoku and Steve4Physics
If the initial velocity of the vertically falling piece is unknown but not equal to zero, it could be virtually any value.
You're telling us that - even given the pieces have unknown trajectories - you can provide a unique solution (one of the given answers in this multiple choice question) ?
I am skeptical.
(I have asked if there is a way to split this side-discussion off from the homework problem so you can be free to post your logic.)
Likes vcsharp2003
I am skeptical.
Sorry, let me review my approach again and then I'll get back.
I am skeptical.
I have reviewed my solution with all unknowns that I mentioned in post#20.
However, I found that I was also making an implicit assumption that the non-vertical exoloded part will take the same time to reach the ground as the initial projectile from ground level took to reach the highest point. I think this assumption will only be true if second part explodes off horizontally. Then, it would logically follow that vertical part explodes off with zero initial velocity.
So, your assumption is as good as mine. Without an assumption, this problem is indeed unsolvable as pointed out by you. I'm sorry for creating false expectations. I'll add an edit to my post#20.
The way I see it, if piece A drops vertically down, the horizontal velocity of piece B will be the same regardless of how much momentum the two pieces acquire in the vertical direction. The more momentum piece B has in the vertical direction, the longer it stays in the air and the more distance it travels in the horizontal direction from the point of the explosion. Without the vertical velocity, one cannot find that distance.
Edited in response to the removal of post #24.
I make the same assumption but for a different reason: the wording of the question says "one of the parts falls vertically". Since no initial v is given, we must assume it is zero, else the question is unanswerable.
Agree. Al though in the context of the question, I'd say it is a very reasonable assumption.
:wink:
If we know that com will take the projectile path as if the explosion hadn't occurred, then can we not say with certainty that when com hits ground, then both exploded parts must also hit it otherwise the com would be above ground level due to the line joining the two parts being slanted to the ground?
For example, the com would be above ground along the slanted line ##m_1m_2##, if both parts didn't touch ground at the same time as com touching the ground.
[If we allow a non-horizontal explosion then] One part can hit the ground first. At which point the center of mass will no longer be in free fall since an external force acts on part of the system.
I think the problem could have been better stated. But a reasonable interpretation of
"A projectile is fired from a cannon at position X. At its highest point, it explodes into two equal parts. One of the parts falls vertically (as shown in the figure) and lands at distance of 1000 m from X. How far (horizontally) will the second part land from X?"
is that no piece of the projectile exceeds the highest point. Ambiguity gone.
Likes vcsharp2003
Was my logic for saying that com should touch the ground at the same time as it's components correct?
If I understand the logic, it is that:
Neither part can tunnel under the ground. If the center of mass is at the ground then both pieces must be on the ground. Proof by contradiction -- if one mass were above ground and the other no lower than the ground then the center of mass would be above ground.
That logic is reasonable. But it provides no assurance that the center of mass is in free fall all the way to the ground.
Likes vcsharp2003
  • #31
We could change the problem slightly. Suppose there is a very deep hole in the ground, so that the vertically falling fragment reaches ground-level but then continues (free-falling) down the hole.
While both fragments are in free-fall, their CoM is in free-fall all the way down to the ground (and potentially through the ground!)
Likes songoku and jbriggs444
  • #32
Yes, the fact that the CoM hits the ground is no guarantee that the two fragments will hit the ground at the same time. Here is the mathematical proof that compares the unexploded trajectory with the trajectories of the to equal fragment.
Let ##V_{0x},~V_{0y}## be the components of the initial velocity. The maximum height where the explosion occurs is ##H=\dfrac{V_{0y}^2}{2g}##. The time of flight for the unexploded projectile is ##T_{\!f}=\dfrac{2V_{0y}}{g}## and the time elapsed until the explosion occurs is ##\frac{1 }{2}T_{\!f} = \dfrac{V_{0y}}{g}##.
Now assume that when the explosion breaks up the projectile into two equal pieces, piece A falls vertically to the ground it has initial velocity ##\vec v_A=\{0,-v_y\}## while piece B has velocity ##\vec v_B=\{2V_{0x},v_y\}## in accordance with momentum conservation. The vertical position of the CoM is $$Y_{\text{cm}}=\frac{\frac{m}{2}y_A+\frac{m}{2}y_B}{m}=\frac{1}{2}\left(H-v_yt-\frac{1}{2}gt^2\right)+\frac{1}{2}\left(H+v_yt-\frac{1}{2}gt^2\right).$$With ##H=\frac{V_{0y}^2}{2g}##, this becomes, ##Y_{\text{cm}}=\frac{V_{0y}^2}{2g}-\frac{1}{2}gt^2## which gives the time of flight for the CoM after the explosion, ##T_{\text{cm}}=\frac{V_{0y}}{g}=\frac{1}{2}T_{\!f}## as expected. The CoM will land horizontally at the same spot as the unexploded projectile as long as the fragments are in free fall for at least time ##\frac{1}{2}T_{\!f}.##
We can now find where the pieces are vertically when the CoM lands.
$$\begin{align} & y_A=\frac{V_{0y}^2}{2g}-v_y \frac{V_{0y}}{g}-\frac{1}{2}g\left(\frac{V_{0y}}{g}\right)^2=-v_y \frac{V_{0y}}{g}\nonumber \\ & y_B=\frac{V_{0y}^2}{2g}+v_y \frac{V_{0y}}{g}-\frac{1}{2}g\left(\frac{V_{0y}}{g}\right)^2=+v_y \frac{V_{0y}}{g}\nonumber \end{align}.$$This shows that if we know that the CoM hits the ground at the same spot as the unexploded projectile, then the two fragments will hit the ground at the same time only if the explosion imparts no vertical momentum to them (##v_y=0##). It also shows that for the CoM to land at the same spot as the unexploded projectile when ##v_y\neq 0##, fragment A must fall through a hole in the ground as @Steve4Physics has argued.
Now consider the hole-in-the-ground suggestion by @Steve4Physics and assume that fragment A keeps falling through it until the fragment B lands. We know that the CoM lands at the same spot as the unexploded projectile at horizonttal distance ##\Delta X_{\text{cm}}=V_{0x}(\frac{1}{2}T_{\!f})=\dfrac{V_{0x}V_{0y}}{g}## from the point of the explosion. To find where fragment B lands, which is the goal of this problem, first we find its time of flight, $$0=\frac{V_{0y}^2}{2g}+v_y t_B-\frac{1}{2}gt_B^2\implies t_B=\frac{v_y+\sqrt{V_{0y}^2+v_y^2 }}{g}.$$Then we can find where the second fragment lands horizontally from the point of the explosion, $$\Delta X_B=2V_{0x}t_B=\frac{2V_{0x}\left(v_y+\sqrt{V_{0y}^2+v_y^2 }\right)}{g}.$$It should be clear that unless we know ##v_y##, we cannot predict where the second fragment will land. If we are not given ##v_y## explicitly we can infer that it is zero with statements such as
(a) Both fragments land at the same time;
(b) Fragment A drops straight down with zero initial vertical velocity;
(c) Fragment B has zero vertical initial velocity.
Lacking such statements, as is the case here, we have to assume that ##v_y=0##, otherwise we cannot answer the question.
Summary
This question can be answered directly by observing that fragment B takes the same amount amount of time to come down as it takes to go up to max height. Since its speed is doubled at max height, it must cover twice the horizontal distance during the down trip.
On edit: Corrected subscript typos and added the summary.
  • #33
So, what was wrong in my logic presented in post#27? I am still trying to figure out where in my logic I overlooked some other facts.
I am unable to come up with a scenario/example where they do not hit the ground simultaneously.
From my logic in post#27, it would automatically follow that the vertical part starts with 0 initial velocity and the other part starts with horizontal velocity, since only then would the fragments reach the ground at the same time as com of whole mass.
  • #34
A = vertically falling fragment (say with non-zero intial vertical velocity).
B = other fragment.
I think the fact that you overlooked in Post #27 is that if A hits the ground first, a new external force acts on A. As a result, the CoM no longer follows its original trajectory.
For the CoM to follow its original trajectory, we need (for example) a deep hole in the ground - so A continues (in free fall) down the hole. Then no new extenal force acts on A while B is also in free fall.
  • #35
And above would happen only if fragment A would explode off with a non-zero vertical velocity. Is that correct?
  • #36
Yes, that's correct.
And if that happened, then of course both A and B would have non-zero initial vertical velocities due to conservation of momentum in the vertical direction.
Likes vcsharp2003
  • #37
B = other fragment.
This problem really doesn't need any com formula or com concepts to solve it. Just projectile concepts and law of conservation of momentum would yield the correct answer. We can simply assume that the fragments are point masses and not bother about how the com of fragments moves after explosion.
  • #38
There is often more than one way to tackle the same problem. And it's worth considering which is the best option.
The original question almost certainly intended for there to be zero initial vertical velocity components from the explosion. One way to solve the problem is then:
1. Realise that fragments (A and B) must land at the same time.
2. Realise that the CoM lands where the unexploded projectile would have landed, 1000m from A, therefore 2000m from X.
3. Realise that the CoM is midway between A and B. Therefore B lands a distance (2000m+1000m =) 3000m from X. Answer ‘e’.
Personally, that's my approach of choice.
Likes songoku, hutchphd and vcsharp2003
  • #39
I think the com approach is shorter and therefore a shortcut, versus the approach using projectile concepts + law of conservation of momentum.
But the shortcut approach would not work when the first fragment fires of with non-zero vertical velocity. Then, only the other approach would work. But, I guess this state of affairs could only happen if explosion occurred during the projectile's upward ascent rather than its highest point.
  • #40
No, that is not the correct criterion.
The shortcut approach would not work when the first fragment fires off with a non-zero vertical velocity relative to the second fragment.
It does not matter whether this happens during the upward part of the trajectory or the downward part or right in the middle. As long as the fragments have equal vertical velocities, they will land simultaneously.
Likes songoku, vcsharp2003 and Steve4Physics
  • #41
And why would the shortcut not be applicable in the special case you mentioned? Is it because the two fragments would land at different instants of time?
  • #42
The shortcut is applicable if the fragments land simultaneously.
Likes vcsharp2003
  • #43
Please read post #33. It shows that the necessary and sufficient condition for the two fragments to land at equal distances from the CoM is that their post-explosion time of flight be the same.
Also, one can do this problem in one's head as indicated #33. It is, of course, applicable only if there is no transfer of vertical momentum between the fragments.
Personally, I think I have said all there is to be said in this thread and say no more.
Likes songoku
  • #44
The OP has been answered, so we can close this thread.
Thanks to all that have contributed.
Likes kuruman
