Solving the Speed of a Projectile Passes an Observation Satellite
  • Thread starter Thread starter talaroue
The problem involves a cannon firing a projectile on an airless planet, with the projectile's speed being calculated as it passes an observation satellite in orbit. The context includes gravitational potential energy and kinetic energy considerations, as well as the effects of the planet's mass and radius.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the conservation of energy principles, questioning the setup of kinetic and potential energy equations. There are attempts to clarify the role of the satellite's mass and whether it should be included in the calculations. Some participants express confusion about the treatment of the satellite's motion and the relevance of relative speed.
The discussion is ongoing, with participants providing guidance on energy conservation and potential energy calculations. There are multiple interpretations regarding the setup of equations and the assumptions made about the satellite's motion. Some participants are encouraged to share their calculations for further review.
There is mention of missing information, such as the mass of the satellite, and the potential confusion regarding the treatment of gravitational effects at different heights. The participants are also navigating the implications of using a uniform gravity assumption versus the actual gravitational field of the planet.
talaroue
A huge cannon is assembled on an airless planet. The planet has a radius of 6.00×106 m and a mass of 3.06×1024 kg. The cannon fires a projectile straight up at 5270 m/s.
An observation satellite orbits the planet at a height of 4103.30 km. What is the projectile�s speed as it passes the satellite?
K=mv^2/2
U=-GMm/r
Initially: Ki and Ui are both present
Finally: Ki and Uf are both present again
CORRECT?
so i have the equation
Ki-Ui=Kf-Uf
wanting to solve for velocity at a certain point Uf actually is GMm/(R+H)
CORRECT?
So then I solved for Vf and get ...
squareroot (2(Ki-Ui+Uf)/m)
Then i plug and go...WHY ISN'T WORKING
You seem to have the basic idea.
Kinetic energy at firing + potential energy gravity at surface = potential energy at satellite + kinetic energy of projectile.
after plugging in the KE and PE equations i came up with...-2(-.5Vi^2+GM/R-GM/(R+h))
square root of the whole thing.
so instead of using the mass of the planet i should use mass of the sataellite?
EDIT: I don't have the mass of the satellite so I believe I have it set up right.
No. Of course not.
The Mass of the Planet and G give you a way to figure your potential energy ...
U = -GM/r
So ...
at surface U = the above.
at the satellite U = -GM/(r+h)
(Don't forget the sign.)
So then the way I set it up is right?
So long as you have also accounted for the potential energy at the surface as well.
You forgot that the satellite is in orbit. It's moving, too.
I attached my equation.
you can't just assume it isn't moving?
I don't think they are asking for the speed relative to the satellite.
Merely the speed at the height (radius) of the satellite's orbit.
thats what I figured. I figured that they just wanted the distance. Is my equation correct that i attached a few posts back?
Looks like the - in front of the 2 is not useful.
I would examine they way you treated the mass of the projectile ... as a suggestion.
The mass should cancel. i meant to erase it, and the 2 shouldn't be negative. I just worked through that equation and it said the answer is wrong.
talaroue said:
It cancels.
Not in the equation you supplied.
Opps that is my bad, I knew it canceled in my mind but when I re wrote it i forgot to cancel it even though I canceled the others.
EDIT: WHen i worked through it, i didn't use the negative or the mass and it was wrong
Has this question been resolved?
Maybe show your work? Perhaps you have a simple error?
Wouldn't it just be easier to use S(t)=-gt^{2}+V_{o}t+h_{o}?
No. That equation assumes a uniform gravity field.
hmmmm i was never able to get it.
Maybe show your actual calculation?
ok ill try to get that on here hold on.
