How High Was the Tree from Which the Squirrel Fell?
  • Thread starter Thread starter Gazaueli
    Fall Free fall
1 reply · 2K views
Gazaueli
Free Fall simple question, Answer check ASAP please!
A flying squirrel falls from the top of a tree, without initial velocity. It travels the last 2 meters of its fall in 0.2s. What was the height of the tree?
d=[itex]\upsilon[/itex][itex]_{i}[/itex]t + [itex]\frac{1}{2}[/itex]at[itex]^{2}[/itex]
[itex]\upsilon_{f}[/itex][itex]^{2}[/itex]= [itex]\upsilon[/itex][itex]_{i}[/itex][itex]^{2}[/itex] + 2ad
1. I first concentrated on the last 2 meters of the squirrel's fall by using the equation d=[itex]\upsilon[/itex][itex]_{i}[/itex]t + [itex]\frac{1}{2}[/itex]at[itex]^{2}[/itex]. I rearranged it to find the initial velocity: [itex]\upsilon[/itex][itex]_{i}[/itex]=[itex]\frac{d-(0.5)at^{2}}{t}[/itex]
For initial velocity, I got
[itex]\upsilon[/itex][itex]_{i}[/itex]=[itex]\frac{(2m)-(0.5)(-9.8m/s/s)(0.2)^{2}}{(0.2)}[/itex]
[itex]\upsilon[/itex][itex]_{i}[/itex]=10.98m/s
2. Now I focused on the rest of the squirrel's fall before the last 2m.
Here I used the equation: [itex]\upsilon[/itex][itex]_{f}[/itex][itex]^{2}[/itex]=[itex]\upsilon[/itex][itex]_{i}[/itex][itex]^{2}[/itex]+2ad and rearranged it to find d: d=[itex]\frac{\upsilon_{f}^{2}-\upsilon_{i}^{2}}{2a}[/itex]
By substitution I got:
d=[itex]\frac{(10.98m/s)^{2}-(0m/s)^{2}}{2(-9.8m/s/s)}[/itex]= -6.15m as displacement.
The displacement here can also be seen as the height, therefore H=6.15m
I then added 6.15m to the last 2m to get H=8.15m
The problem however is that in the corrections provided by my professor, his answer is that the height of the tree is 6.15m
His work looks like this:
[itex]\upsilon[/itex][itex]_{i}[/itex] (last 2m)= [itex]\frac{2m}{0.2s}[/itex]-[itex]\frac{(9.8m/s/s)(0.2s)}{2}[/itex]= 9.02m/s
Did he forget to square the time here?
And in the second part he then calculates: d=[itex]\frac{(9.02m/s)^{2}}{2(9.8m/s/s)}[/itex]+2m=6.15m
Can someone please check if I missed something, or if perhaps my prof's answer is incorrect?
Thank you!
Recheck that calculation. The value you've given corresponds to the impact speed at the ground, not the speed at 2m. Could be you've selected the result from a different calculation.
Thank you!
