How Is Force Calculated on a Submerged Object's Window at Extreme Depths?
  • Thread starter Thread starter iseidthat
    Force Submerged
The discussion focuses on calculating the force exerted by water on an underwater vehicle's observation window at a depth of 10,550 m in the Mariana Trench. The pressure at this depth is calculated using the formula P = pgh, resulting in a pressure of approximately 1.06 x 10^8 Pa. To find the force on the circular window with a radius of 0.1 m, the area is determined using A = πr², yielding an area of about 0.0314 m². The final force exerted by the water on the window is calculated to be approximately 3.33 x 10^6 N. The discussion clarifies the relationship between pressure, area, and force in this context.
iseidthat
In this problem, please make sure to use the density of seawater = 1025 kg/m3.
The bottom of the Mariana Trench, located in the Pacific Ocean, is about 11,000 m below the ocean's surface, making it the deepest ocean depth on Earth.
If an underwater vehicle were exploring the region, at a depth of 10550 m,
a.) What force would the water exert on the vehicle's circular observation window, which has a radius of 0.1 m?
P= pgh
P=pgh=1025 x 9.81 x 10550= 1.06 e8 Pa
i don't really get how the radius relates...
and if I'm suppose to find the buoyant force, how do i find it without the mass or volume?
How does pressure relate to force?
P= pgh
You calculated the pressure correctly; the problem wants not the buoyant force, but rather, the force of the water pressure on the window. How is force and pressure related?
well
F=P x A...but i don't have the area...
i know radius is 0.1 m, but i don't know the other dimensions.
ohhh its a circular window! ahah i misread it.
so the area of a circle :
A=pi r^2=pi(.1m)^2=.031416 m^2
so F= 1.06 e 8 x .031416 =3.33 e 6
mmmk thanks :)
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
