How is relativity theory applied to gps?
The application of relativity theory to GPS technology is critical for maintaining accurate time synchronization between satellites and Earth-based clocks. General Relativity (GR) and Special Relativity (SR) adjustments are made prior to satellite launch to account for time dilation effects, resulting in a net gain of approximately 38 microseconds per day. If these relativistic effects were ignored, GPS signals would accumulate a timing error of about 39 millionths of a second per day, leading to a positional drift of approximately 11.6 kilometers. Regular resynchronization of satellite clocks is necessary due to additional factors such as elliptical orbits and clock drift.
  • Understanding of General Relativity (GR) and Special Relativity (SR)
  • Familiarity with GPS technology and satellite operations
  • Knowledge of time dilation and gravitational redshift concepts
  • Basic grasp of the Schwarzschild metric in physics
  • Research the effects of gravitational time dilation on satellite clocks
  • Study the Schwarzschild metric and its applications in GPS technology
  • Explore the process of GPS clock resynchronization with Earth-based systems
  • Investigate the cumulative effects of elliptical orbits on GPS accuracy
Physicists, aerospace engineers, GPS technology developers, and anyone interested in the practical applications of relativity theory in modern navigation systems.
francisco
how is relativity theory applied to gps?
thanks
The clocks in the satellites have to be very precise. General relativity is needed to correct the clocks compared to what they would do if they were sitting on the ground.
The clock tick rates are actually adjusted for SR and GR prior to launch, meaning while sitting on the ground, they don't stay synchronized with earth-based clocks, but once in orbit, they do.
Yes, time dilation causes the satellites' clocks to lose about 7us per day, and gravitational redshift causes them to gain about 45us. The net effect is a gain of 38us per day which, as Russ said, is accounted for by adjusting the frequency of the clocks when they are on the ground.
Check out http://relativity.livingreviews.org/Articles/lrr-2003-1 (especially section 5) for information on the subject from Neil Ashby, one of the leading experts on the physics of GPS.
As mikeu has said, if gravitational time dilation is not taken into account, a time error between the ground and the satellites accumulates at the rate of about 39 millionths of a second per day. Distance is determined by timing signals that pass between the ground and the satellites. A rough estimate on the error in position that this causes can be obtained by calculating the distance that a signal moving at the speed of light travels in 39 millionths of a second. This gives 11.6 kilometres.
To show this, I'm going to play fast and lose with differentials, but I am not going to split things up into different effects. The analysis that I give below isn't as accurate or as detailed as Ashby's, but it's still pretty good.
The Schwarzschild metric reveals (almost) all!. Let m be the mass of the satellite and M be the mass of the Earth. For \theta=\pi/2, the Schwarzschild metric is
<br /> d\tau^{2}=\left( 1-\frac{2M}{r}\right) dt^{2}-\left( 1-\frac{2M}{r}\right) <br /> ^{-1}dr^{2}-r^{2}d\phi^{2}. <br />
Consider 2 clocks, 1 rotating along with the Earth on the Earth's surface and one in an orbiting satellite. Boths clocks have constant r values, so dr=0 for both clocks, and, after factoring out a dt^{2} the above equation becomes
<br /> \left( \frac{dt}{d\tau}\right) ^{2}=1-\frac{2M}{r}-v^{2}, <br />
where v=rd\phi/dt is, approximately, the speed of something moving along a circular path. Use this equation twice - once for the clock on the Earth and once for the clock on the satellite.
How is v found? By using Newtonian gravity in flat space(time)! I will proceed without justifying this approximation. A clock at the equator on the Earth moves 1 Earth circumference in 1 day, so
v_{Earth}=\left( 2\pi r_{Earth}\right) / \left( 1 day\right) = 1.544\times10^{-6} <br />
in relativistic units. For the satellite, setting centripetal force equal to Newtonian gravitational force results in
<br /> m\frac{v_{sat}^{2}}{r_{sat}}=\frac{GmM}{r_{sat}^{2}}. <br />
Using this with v_{sat}=\left( 2\pi r_{sat}\right) /T, where T=12 hours is the period of the satellite's orbit, gives r_{sat}=2.611\times10^{7} and v_{sat}=1.2910\times10^{-5}.
Now,
<br /> \frac{d\tau_{sat}}{d\tau_{Earth}}=\left( \frac{d\tau_{sat}}{dt}\right) \left( \frac{d\tau_{Earth}}{dt}\right) ^{-1}=\sqrt{\frac{1-\frac{2M}{r_{sat}}-v_{sat}^{2}}{1-\frac{2M}{r_{Earth}}-v_{Earth}^{2}}}. <br />
Plugging values into some calculators won't work because the result is
<br /> \frac{d\tau_{sat}}{d\tau_{Earth}}=1.0000000004479=1+4.479\times10^{-10} <br />.
The error accumulated over the course of one day is 4.479\times10^{-10}\times 1 day=38.7\times10^{-6} seconds.
Regards,
George
One other note of interest is that while the large GR effects are very pronounced and GPS would nearly immediately be off by a mile (no pun intended) if those considerations were not in the timing, the fact that the satellites are in elliptical orbits, combined with the random drift of the clocks themselves (3 us/day I think it was?)along and other small effects (sagnac and perhaps lense-thirring) requires that they be re-synchronized with Earth clocks on a regular basis.
So while it is a beautiful GR test, I believe the level of error actually exceeds the kinematic effects over time and so it is not the best SR lab from what I hear.
Does anyone know how frequently they are reset? I thought I heard daily.
They are reset every time they pass over a ground station. But the drift rate due to SR and GR is substantially higher than the error in the clocks themselves, so they do make an excellent test-bed for Relativity.
You sure?
I know the GR effects are significantly higher but I'm pretty sure the kinematic (SR) effects are not higher than all the errors. When you add clock drift, eliptical orbit and all the other effects, I think the total cumulative errors are roughly the same size as the kinematic shift.
I'll have to see if I can't find a few good links to see if I'm wrong about that.
I like to be precise...
George's workthrough (#5) to 38.7us/day is impressive. It is sometimes said that if that figure were not taken into account, the position indicated by a GPS user device would drift by about 11km/day but I've never seen an accompanying explanation. Multiplying 38us/day by the speed of light yields 11.6km/day but I don't see that explaining an about 11km/day indicated position drift. Anyone got any ideas?
  • · Replies 103 ·
  • · Replies 31 ·
  • · Replies 34 ·
  • · Replies 20 ·
  • · Replies 69 ·
10K
  • · Replies 22 ·
