How Long Does a Particle Stay in a Quantum Potential Well?
The discussion centers on calculating the duration a particle remains in a quantum potential well defined by the potential function \( V(x) \). The potential well consists of three regions: infinite potential for \( x < 0 \), a constant negative potential \( -V_0 \) for \( 0 < x < R \), and a varying potential for \( x \geq R \). The transmission coefficient \( T \) is utilized to determine the tunneling probability, leading to the expression \( \lambda = vT \), where \( \lambda \) represents the quantum tunneling rate. The lifetime of the particle in the well is then calculated as the reciprocal of this rate.
  • Quantum mechanics fundamentals
  • Understanding of potential wells and quantum tunneling
  • Familiarity with the Schrödinger equation
  • Knowledge of transmission coefficients in quantum physics
  • Study the derivation of the transmission coefficient \( T \) in quantum mechanics
  • Learn about the Schrödinger equation for one-dimensional potential wells
  • Explore quantum tunneling phenomena and its applications
  • Investigate the implications of varying potential functions on particle behavior
Physicists, quantum mechanics students, and researchers interested in particle behavior in potential wells and quantum tunneling effects.
andrewtz98
Let's suppose I have a potential well: $$
V(x)=
\begin{cases}
\infty,\quad x<0\\
-V_0,\quad 0<x<R\\
\frac{\hbar^2g^2}{2mx^2},\quad x\geq R
\end{cases}
If ##E=\frac{\hbar^2k^2}{2m}## and ##g>>1##, how can I calculate how much time a particle of mass ##m## and energy ##E## will stay inside the well?
I'm thinking of using the expression of the transmission coefficient: $$T=e^{-2\int_{x_1}^{x_2}dx\sqrt{\frac{2m}{\hbar^2}[V(x)-E]}}$$
and ##\lambda=vT##, where ##\lambda## the probability per unit of time for the particle to pass through and ##v## the number of collisions per second. Any help would be appreciated.
The expression you wrote down for $$ \lambda = \nu T $$ should give you the quantum tunneling rate. To find the lifetime of the particle in the well, find the reciprocal of the rate.
  • · Replies 27 ·
  • · Replies 21 ·
