How Long Does It Take for a Mass to Oscillate Between Two Points on a Spring?
5 replies · 3K views
shasanni
A vertical spring stretches 9.6 cm when a 1.3kg block is hung from its end.This block is then displaced an additional 5.0 cm downward and released from rest. Calculate the time it takes the object to go from a point 0.025 m below its equilibrium position to a point 0.025 m above it.
X1= Acos(Wt1)
X2=Acos(Wt2)
A represents the amplitude, which is 0.05 m. The W represents the angular frequency, which is 10.1
This is how I sent things up:
0.025=0.05cos(10.1t1)
-0.025=0.05cos(10.1t2)
and then I would have subtracted the two times, but I am not getting the correct values for t1 and t2. What am I doing wrong??
Btw, the answer is supposed to be 0.1s. T2 is 0.2s and T1 is 0.1s. ?
cos(ωt1)=0.5 corresponds to ωt1=π/3.
cos(ωt2)=-0.5 corresponds to ωt2=π-π/3.
What are t1 and t2 then?
ehild
i think I know what the issue is. I have been using radians, not degrees!
t1 should 0.1 seconds and t2 should be 0.2 s. The change in time should be 0.1 seconds, which is the answer.
Well done! take care of radians and degrees in the future.
ehild
