When Should the Violinist Play Her Note? Understanding Timing in an Orchestra
  • Thread starter Thread starter physics(L)10
The discussion focuses on the timing synchronization required for a violinist and a drummer in an orchestra to ensure their notes are heard simultaneously by a listener. The violinist should wait approximately 0.1 seconds before playing her note to account for the sound delay from the drummer, who is 33 meters away. The speed of sound in air is taken as 330 m/s, while the speed of light is effectively instantaneous for this scenario, making its delay negligible. The problem emphasizes that the timing issue is primarily a kinematics question rather than a wave equation problem.
  • Understanding of basic kinematics principles
  • Knowledge of sound speed in air (330 m/s)
  • Familiarity with the concept of light speed (3 x 108 m/s)
  • Ability to perform basic algebraic calculations
  • Research the principles of kinematics and their applications in real-world scenarios
  • Explore the differences between sound and light propagation in various mediums
  • Study the effects of distance on sound delay in orchestral settings
  • Learn about synchronization techniques used in live performances
Musicians, conductors, sound engineers, and anyone involved in orchestral performance who needs to understand timing and synchronization in music.
physics(L)10
An orchestra wants to have a listener in front of a conductor hear notes at the same time, played by the violinist located next to the conductor and from a drummer located 33m further back.
a) How long should the violinist wait before playing her note? (assuming drummer plays as soon as conductor gives command)
b) Why may one assume that the two players see the conductor command at the same time?
I really have no clue on how to attempt this, I don't know where to start. I really need your guys help please.
sound and light both travel at certain speeds. How long does it take for the light to travel to the drummer from the conductor and how long does it take sound to travel to the conductor from the drummer?
Would I use the equation speed of light=(frequency)(wavelength) and then solve for frequency? Speed of light = 3x108 and wavelength = 33m?
No. What is the basic relationship between time spent traveling, speed, and distance traveled?
speed = distance / time
normal / average speed of sound in air is taken as 330 m / s
330 = 33 / t
t = 33 / 330 = 0.1 seconds.
Did you mean anything like this ?
Frequency?
physics(L)10 said:
Frequency?
No. Even though it's against the rules to do peoples' homework, look at the post above you. This problem has nothing to do with frequency.
You can think of light and sound both traveling in a straight beam at a constant speed. The problem basically asks you to calculate how long it takes that beam of sound to travel from the drummer to the listener. If there is some delay T between the drummer playing and the listener hearing whereas the delay is 0 for the violinist playing and the listener hearing, to synchronize the music, you'd make the violinist wait time T and then start playing. Does that make sense?
Also, when you do the same calculation for T but with light (the time it takes for the beam of light to travel from the conductor to the drummer, representing the delay between the "go" signal and when the drummer sees it), you will find it is extraordinarily tiny and basically rounds to zero when added to the delay caused by sound. Therefore, its contribution is irrelevant compared to the delay caused by sound.
So basically it has nothing to do with any wave equations? It`s more of a kinematics question?
So light would be:
3x108=33/t
t=33/3x108
t=1.1x107
So you would just add the two and it would basically be 0.1sec that the violinist should wait since t is so small for light?
b) They see the same players at the same time because the speed of light is so fast compared with sound?
So light would be:
3x108=33/t
t=33/3x108
t=1.1x107
Yes. For b, I wouldn't say they see the signal at the same time. I'd say the order of magnitude in the visual delay is far less than order of magnitude of the delay caused by sound, so you can ignore it without affecting your answer.
Alright, thanks a lot :D
11K
10K
