rewebster
- 883
- 2
Klockan3 said:So, you say 3.1?
the (one) decimal is the decimal (point/dot)
I don't think I could do it in 15 minutes if I tried right now. And probably not in an hour even - unless I figure out some clever trick to memorize it. In general though, the way I memorize things is by seeing/using them periodically (i.e., through familiarity). I'm terrible at committing to memory by repeated recitation, like I've seen others do, but that's also probably because I have not put much effort into developing that skill.Klockan3 said:I saw this post yesterday and thought; maybe I should look at this pi! Doesn't take that long memorising raw numbers, now I know:
3.
1415926535 8979323846 2643383279 5028841971 6939937510 5820974944 59
I am sure you know much more digits than that, associated to different things than pi though. I mean 4 digits take ~1 minute to memorize, so the above string should take roughly 15 minutes. Not that much of your life.
The trick is to want to memorize, at least for me. If I don't care I will only remember bits but when I focus I can remember just about anything indefinitely. The problem is of course that you can't just conjure up such focus at will.Gokul43201 said:I don't think I could do it in 15 minutes if I tried right now. And probably not in an hour even - unless I figure out some clever trick to memorize it. In general though, the way I memorize things is by seeing/using them periodically (i.e., through familiarity). I'm terrible at committing to memory by repeated recitation, like I've seen others do, but that's also probably because I have not put much effort into developing that skill.
Pinu7 said:Pi is around 3-ish.
pi-70679 said:I just find that learning pi is a good way to maintain your memory active, plus it's a really good time waster. I found out that now i can remember series of numbers in a lot less time. I just use birthdates, repeating numbers, and my latest, pattern you do with your fingers when you type the keys on the numpad.
