Dragonfall
- 1,023
- 5
If we accept the many-worlds interpretation, how many parallel worlds are there? Finite? Countable? Uncountable? Even bigger? Do we need to bring the continuum hypothesis into it?
Dmitry67 said:different branches which don't interact.
MathematicalPhysicist said:Unaccountable.
2^null_aleph
The explanation is rather simple, if every bit of infomartion is decoded to 0 or 1 (nay or yay) then the number of world is the number of sequences of 0 and 1, which we know from set theory what it is.
Max Tegmark said:The answer is that there are only a finite number of possible states that a Hubble volume can have, according to quantum theory
Although classical physics allows an infinite number of possible states that a Hubble volume can be in, it's a profound and important fact that quantum physics allows only a finite number.
Let's first ignore the important complication of past history and ask how many physically distinct states N there are in a volume V. In classical physics, N is infinite (indeed uncountably infinite) as you say, since even specifying the position of a single particle requires infinitely many decimals. In quantum mechanics, however, N is finite: if the temperature never exceeds T, we of course have N < ln S, where S is the entropy of the thermal state with temperature T (I'm taking Bolzmann's constant k=1). Interestingly, the number of states appears to be finite even when taking general relativity into account, which is closely related to the holographic principle: the entropy is maximized if all the matter in V is in a single black hole, in which case, as you know, the Bekenstein-Hawking formula says that N is of order the surface area measured in Planck units. So yes, I see your reasoning, and find it quite striking that quantum mechanics, uncertainty principle and all, contrary to what one might expect, gives fewer states than classical physics. In the limit V->oo, quantum mechanics therefore gives a countable rather than uncountable infinity of states
Quantum physics tells you that before experimenting you have a probability for certain outcomes.Dragonfall said:I don't see how this is related to quantum physics, or the many-worlds interpretation.
yossell said:I didn't understand your reply. How are these strings of 0s and 1s being generated? Why does every outcome correspond to an infinite string of 0 and 1, and why does every infinite string of 0 and 1 correspond to an outcome? You need a 1-1 correspondence between the two to get the result.
