How many ways can 2 1x2s be rotated to fit into a sphere?
  • Level: Undergrad
  • Thread starter Thread starter Loren Booda
    Sphere
22 replies · 5K views
Loren Booda
How many cubes of side 1 centimeter can fit into a sphere of diameter 3 centimeters?
Mathematics news on Phys.org
Mark44 said:
I'll say 8.
Since the volume of such a sphere is ~ 9.42 cm3, no more than 9 unbroken cubes could possibly fit into this sphere
Try again.
I certainly agree. If you can't bend or break the cubes or the sphere you can't fit 8.
It is natural to think so though. You can fit four squares of side length 1 into a circle of diameter 3. You can easily see this, the equation for a circle at the origin with diameter 3 is x^2 + y^2 = 2.25. So if you put the four corners of squares at the origin you can see they fit because the point (1,1) fits well within the circle since 1^2 + 1^2 < 2.25
However in 3 dimensions the equations change a bit. Here you have the sphere as x^2 + y^2 + z^2 = 2.25 and if you tried to fit 8 cubes all with corners meeting at the origin you would need the point (1 , 1, 1) to be inside the sphere. But alas, 1^2 + 1^2 + 1^2 > 2.25.
I think the answer here is again 4 cubes. And this depends on whether or not you allow the cubes to intersect the sphere in exactly one point.
For if the centered the four cubes at the origin their corners would hit the points (+/- 1, +/- 1, +/- .5) and here you have the corners intersecting with the sphere since 1^2 + 1^2 + .5^2 = 2.25
Close enough.
Four, stacked 1 x 2 x 2. By the Pythagorean theorem, 1^2+2^2+2^2=3^2.
I say 4, arranged tetrahedrally.
[EDIT] Doh! I came up with that answer before seeing Diffy's.
Dickfore said:
I would say 6.
Arranged how?
DaveC426913 said:
Arranged how?
Imagine a cube with all vertices on one of its side touching the sphere. The height of the spherical cap cut by the opposite side of the cube is:
[tex] h = a + R - \sqrt{R^{2} - \frac{a^{2}}{2}}[/tex]
Inside the spherical cap, it's impossible to accommodate one more cube. Imagine doing this on six orthogonal directions. We cut 6 spherical caps and the central region is a cube with a side:
[tex] b = 2 R - 2 h = \sqrt{(2 R)^{2} - 2 a^{2}} - 2 a = \sqrt{7} - 2 = 0.646 < 1 = a[/tex]
Therefore, we cannot accommodate a single extra cube in this internal cube.
OK. So arranged how? You said six cubes. How do you see them being arranged?
P.S. Must. Try. So Hard. To Take. You Seriously.
Username... Seriousness fading...
DaveC426913 said:
Uh. OK. So arranged how? You said six cubes. How do you see them being arranged?
Imagine a Cartesian coordinate system. It cuts the sphere at six points. You place the cubes "near" these points.
Still having trouble.
1] Seems to me it would cut the sphere via planes, not points.
2] Do these 6 cubes touch each other?
Oh, I think I see. We're all building a mass of cubes glued together in the middle. You're attaching the cubes to the inside surface of the sphere. So, they touch the sphere at 6 equidistant points. They may or may not touch each other.
No, each cube touches the sphere with 4 points, but there are 6 such cubes situated around the intersections of the coordinate axes with the sphere. They do touch each other. That is why we cannot insert a cube in the central cube. The plane in which the opposite sides of each cube lie form a cube inside the sphere.
Ahh:
They will block each other. In this way, I will only be able to put 2.
Dickfore said:
Ahh:
Right.
My guess is that the tetrahedron, if it fits, would be asymmetric. Please describe your array.
There can definitely be 4 cubes. Just order them to form a square prism with side 2 and height 1. Here is the relevant diagram.
Mark44 said:
I'll say 8.
I made it 14.137 cm3 which is reasonable as a 3x3x3 cube is 27cm3
sin 45 = 1.06 so you won't get a 2x2x2 cube in.
You will get a 2x2=4 in easy, then I think you can squeeze another in on top of that, but that's you lot. So I say 5.
Don't think you can get a sixth one in.
whether we allow the vertices of the cubes to touch the surface of the sphere or not, I say just 2 cubes fit inside.
can you upload that image to imageshack or something? I'd like to see it and it's saying "pending attachment aproval" on my end... :(
[PLAIN]http://img231.imageshack.us/img231/3039/cubes.png
No. The tetrahedron is the same as the 1x2x2 square, just with one pair rotated 90 degrees.
So, if the 1x2x2 can fit, then any pair of the four can be rotated (and by any amount, not just 90 degrees).
This is why I realized I was overly-complicating things. Restricting it to a tetrahedron is assigning needless structure. It is simply 2 1x2s rotating at any angle (inclduing zero) through a common axis.
