How much force do I exert on the Earth?
cs44167
Calculate your acceleration while jumping, the net force that acts on you while jumping, and the force you exert on Earth when you jump.
w = mg
acceleration = Net force / mass
2.2 lb = 1 kg
This question required measurements which are the following:
my weight = 108 lbs
crouching distance (the distance from my regular height to where I crouch) = 90.6 cm
jump height = 60.4 cm
I first converted lb to kg, and I got 49.09 kg. I then used this value for w = mg and inputted 9.80 for g and got w = 481.09 N. I then used this force for a = net force / mass and found the acceleration to be 9.7999 m/s/s.
This answer was wrong, and I was wondering why I went wrong in my work. The answer made sense to me — the only force, neglecting air resistance, acting on someone in the middle of their jump is acceleration due to gravity.
Hello Cesium, :welcome: !
Doesn't your result (9.7999 m/s) look a lot like ##g## ?
(Small wonder if you first do ##W = mg## and then ##a = W/m## :smile: )​
I envy your 60 cm !
Jumping has three phases: you go from crouching to right up (accelerating), then you fly (basically free fall) and when you land you crouch again to soften the landing (decelerating).
That surprises me: I agree with your reasoning and with your result. How do you know it's wrong (do you have the right answer, or just a red cross or something ?)
Perhaps - if your teacher is a computer in a strange backward country, the answer is expected to be expressed in antique units ? (Such as lbf, feet/forthnight2 or other :wink:)
I envy your 60 cm !
It’s on a website and gives a red x when the answer is incorrect. There’s never been an issue and the answer for acceleration is to be expressed in m/s/s. The only thing I was thinking was since acceleration is a vector if not having a negative sign was the issue.
We have three submissions, the first I put 9.80 m/s/s, then -9.80 m/s/s, and now I’m stuck.
I'm afraid I am stuck as well. Doesn't help but perhaps feels a little better.
I don't suppose the website is accessible for pagans from outside ?
The correct answer is a maximum upward acceleration a=.67g. This is what is required to produce a jump height of 60.4cm with an acceleration stretch over a distance of 90.6cm. Then add in the weight.
I didn't read that in the problem statement, but I can understand that it's somewhat implicitly intended (semantics?). So a jump ends in that interpretation once the object leaves the ground.
@cs44167: If your career doesn't depend on it or you have more tries left, give it a try !
@hutchphd : you seem to know the website ?
Perhaps I overstated...I think the correct answer is 1.67W... I don't know the website. Be glad to help more tomorrow.
