How much force might an electron withstand?
  • Level: High School
  • Thread starter bkelly13
38 replies · 4K views · last reply
I think that you are right in this statement. My view is that we have mathematical models and experiments that shows the behaviour of protons, electrons, quarks...and these models show us that these particles behave as if they are a balls in certain metrics and as if they are the waves in another one. I don't see them as a ball-wave that is present in some popular literature. I see them as an third entity that shows these behaviours depending on the measurement we make. Imagine the spring that is presurized and thrown from the hand. From the large distance, it seems that somebody has thrown a solid object. But from the small distance, it is a wave. With a mass. This is a macroscopic analogon of something much more complex but it seems to me that it could be used as a preliminary explanation of a duality of a subatomic particles. Maybe I am wrong but this is my understanding. And yes, we don't know what it really is. We know the mathematical relationships but we don't know what the force is, what is the mass and what is the time. We don't know much more but I'll stop here. Excuse me for my bad English, it is not my maternal language. I am open for corrections, I am not a physicist so maybe I am wrong in some statements.
Herman Trivilino said:
Someday maybe we'll know everything, but based on the history of knowledge, I don't think so.
When we think we know everything, we have only found a model that correctly predicts everything, without exception. There is nothing to say it is the only model, or the simplest model.
How is a spring a wave?
A spring can be a medium for a wave. Stretch out a slinky, for example, and you can get both longitudinal and transverse waves to travel along the spring.
The notion of touching something is an illusion. There are electromagnetic forces that repel whatever it is you think you are touching.
Experiments show that the size of the electron, if it is nonzero, is less than about ##10^{-18}## m. All attempts at measuring its size have simply lowered this upper limit.
The electron appears to have certain properties such as mass, charge, spin, etc. But size is not one of those properties. As far as we know, according to the evidence we have, (a qualifier that applies to all scientific knowledge) it has a zero size.
And EDM measurements constrain P- and T-violating electromagnetic asymmetry to the order of ##10^{-30} e \cdot \mathrm{cm}##. If the electron possesses internal structure, there is no a priori reason to assume that structure would be perfectly symmetric. However, a finite intrinsic radius below current experimental bounds is entirely compatible with a vanishing or experimentally undetectable EDM. The EDM is constrained not only by the spatial configuration but also by the symmetries of the underlying quantum dynamics. Even within the point like description of the electron, the Standard Model predicts an extremely small but nonzero EDM. Consequently, neither a vanishing EDM implies point like structure nor does point like structure imply a vanishing EDM.
That said, I'm skeptical that the electron is truly point like in a physical sense. There is historical precedent for particles originally modeled as point like subsequently being found to possess internal structure, as was the case with nucleons. While this is not evidence against the point like electron, it illustrates the distinction between a successful mathematical representation and an experimentally established physical property. Nevertheless, we have no observable evidence of a finite intrinsic radius, and nearly a century of theoretical and experimental development has not demonstrated a need for one.
Imagine the long spring. Press it. Release it abruptly. What will you get? The spring by itself is not the wave. But you'll get the wave on it. The spring will show wavelike behaviour.
It is clearly not the same wave-particle duality of quantum mechanics. Maybe I missed the spring double slit experiment.
