Amount of Phytoplankton in Sea Water
  • Thread starter Thread starter Sundog
The amount of phytoplankton in seawater, particularly around reefs and near the surface, is typically measured using satellite telemetry based on chlorophyll levels, which are then converted to biomass. Phytoplankton biomass is highly variable, with significant fluctuations occurring during algal blooms in late spring and late summer. Estimates indicate that phytoplankton contributes approximately 1% of the global biomass, translating to about 5 billion metric tons of carbon in the oceans. Measurements are influenced by factors such as vertical distribution and time of day, with the highest concentrations found within 30 meters of the surface during midday.
  • Understanding of chlorophyll measurement techniques
  • Familiarity with satellite telemetry for biomass estimation
  • Knowledge of algal bloom dynamics in marine ecosystems
  • Basic concepts of vertical distribution in aquatic environments
  • Research satellite telemetry methods for measuring chlorophyll levels
  • Explore the dynamics of algal blooms in temperate waters
  • Investigate the impact of vertical distribution on phytoplankton biomass measurements
  • Learn about bathymetric devices used for sampling water and depth
Marine biologists, ecologists, environmental scientists, and anyone interested in understanding phytoplankton dynamics and their role in marine ecosystems.
Sundog
Does anyone know how much phytoplankton is in sea water? Say surrounding reefs and near the surface? I couldn’t find a number so I don’t know if it would be in ppm or something els.
Thanks!
Biology news on Phys.org
Sundog said:
how much
Are you measuring in individuals per (? (what unit of distance or area?)).
Phytoplankton biomass is often measured by satellite telemetry, based on chlorophyll levels in the uppermost water column. And then converted to biomass.
In Northern (and Southern) temperate waters, there is what is called an 'algal bloom' in the late meteorological spring. Another smaller bloom occurs in late summer. For these reasons and many others, phytoplankton biomass is ephemeral (comes and goes by orders of magnitude) value in a given ecosystem. In other words, it is a value that can change often. And a lot. So estimates are often a percent of total biomass.
And measurements are affected by the vertical movement of plankton in the water column. -- vertical distribution of the organisms changes by time of day, and one gets varying results over the duration of a day, since the top layer is what is measured by telemetry. Bathymetric (depth measuring) devices that sample water as well as depth, can bring small samples to the surface. Phytoplankton is usually within ~30m of the surface (depends on time of year, water temperature, nutrients, etc.), with the greatest concentration of phyto-beasties very near the surface during mid-day. In early June (or December).
Fuzzy answer from wikipedia:
Apart from bacteria, the total global biomass has been estimated at about 560 billion tonnes C. Most of this biomass is found on land, with only 5 to 10 billion tonnes C found in the oceans. ... It has been estimated that about 1% of the global biomass is due to phytoplankton, and 25% is due to fungi.
If you really want details, please read:
https://en.wikipedia.org/wiki/Biomass_(ecology)
Anyway, the phytoplankton biomass estimate works out to 5 billion metric tons of carbon, which is how biomass is reported. Not chlorophyll.
@Ivan Samsonov
Phytoplankton in a more closed system like a pond or a small given body of water is sometimes reported as Xminimum - Xmaximum mg/ml of chlorophyll - usually for a specified date range. And then a biomass estimate may (or may not) be derived from those values.
Whatever you could find or know. I can’t seem to find anything.
Thanks! Good info
  • · Replies 23 ·
  • · Replies 47 ·
  • · Replies 42 ·
9K
  • · Replies 28 ·
10K
