How to Calculate Acceleration and Average Speed in a Road Test
  • Thread starter Thread starter chaos17
    Dimensions Motion
The problem involves a car that accelerates uniformly from rest over a distance of 400 meters in 18.5 seconds, followed by a braking phase where it stops in 4.9 seconds with constant deceleration. The questions focus on calculating the acceleration during the initial phase and the average speed over the entire journey.
  • Participants discuss the calculation of acceleration using the velocity obtained from the first part of the problem. There is a suggestion to split the problem into acceleration and deceleration phases. Questions arise about how to find the final velocity during deceleration and the average velocity for the entire journey.
Some participants have provided guidance on how to approach the calculation of acceleration and have confirmed that the initial calculations appear correct. There is ongoing exploration of how to tackle the second part of the problem, with requests for hints or further assistance.
Participants are navigating the constraints of the problem, including the need to find unknown variables such as final velocity and distance during deceleration, while adhering to homework guidelines that may limit the type of assistance provided.
chaos17
In a road test,a car was uniformly accelerated from rest over a distance of 400m in 18.5s. The driver then applied the brakes, stopping the car in 4.9 s with constant deceleration.
a) calculate the acceleration of the car for the first 400m.
b)Calculate the average speed of the car for the journey covering both the acceleration and braking distances.
v=d/t
avg speed=distance / time
a)v=d/t
v=400/18.5
=21.62ms^-1
b) I have no idea, I don't know what to do. Could someone give me a hint on what values to use or what formula to use.
Is my part a right?
what i mean by part a being right is that do i then use v to work out acceleration? Or is this a wrong way?
From what I can see, part (a) is right. The first thing that would be good to do is, to split the acceleration and the deceleration sections up. As you know the velocity of the first part, you need to find the velocity of the second part. How would you go about doing that, as you have the time and the initial velocity of the car, but you do not have the deceleration, final velocity or the distance the deceleration acts over. You do not need to know all everything, just enough to find out the average velocity over the whole[b/] time.
In reply to second post by Chaos: I believe you are on the right track. What equation do you use to then work out acceleration, when you have the velocity, time and distance?
I would them use avg acceleration= change in velocity / time.
Now that I think of it, wouldn't part a be:
u=0, t=18.5, x=400
x=ut+0.5at^2
so 400=0.5 * a * (18.5^2)
a=400/171.125
a=2.34m^-2
I think that is right.
But them what do I do for part b.
can anyone help for part b?
  • · Replies 20 ·
