How to calculate percentage increase from 300 to 3,850
  • Topic:
  • Thread starter Thread starter riffwraith
    increase
6 replies · 2K views
riffwraith
Hi all. Hopefully this is in the right place.
I tried using an online percentage calculator, but it's not giving me the correct results, and was hoping someone here could help me.
From 300 to 3,850 - what percentage increase is that?
-and-
From 300 to 5,000 - what percentage increase is that?
Again, the online calcs I have tried aren't working properly, and I have no idea how to do this with a regular calculator. Is there a formula for this? :/
Thanks in advance.
Hi riffwraith and welcome to MHB! :D
Dividing 3850 by 300 will give you the correct answer:
$$\frac{3850}{300}\approx12.83$$
Multiply the RHS by 100:
$$12.83\cdot100=1283$$
So $300$ increased by $1283\%$ is $3850$ (which is approximate due to rounding.)
Can you apply this to the second problem? Do you need any clarification?
Thank you! :)
Based on what I see - assuming I understand correctly - 300 increased by 1666% is 5000.
That correct?
riffwraith said:
Thank you! :)
That correct?
$$300+300\cdot\frac{1666}{100}=300(1+16.66)=300\cdot17.66=5298$$
Here, we have taken 300, and added 1666% of 300 to it. However if we multiply 300 by 5000/300 we will get 5000.
$$\frac{5000}{300}=\frac{5000}{3}\%=1666.\overline{6}\%$$
So, we can say 1666% of 300 is roughly 5000, but if we increase 300 by 1666% we will get a larger number, namely 5298. Do you see the difference?
https://percentagecalculator.net/
"percent" means "per hundred"
Simple example:
200 increases to 218: that's "9 per hundred", right?
Henceforth***:
200 * 1.09 = 218
***I went to French school (grades 1 - 8),
then to English school (grades 9 - 13);
I noticed that Mr Fraser (my English Lit teacher)
loved the word "henceforth", and used it often...
Soooo...I'd use it on tests and always got a pass mark :)
I think - it seems as tho the final # you wind up with will vary depending upon which direction you go, and/or what the starting point is.
Cheers.
Cheers.
300 + 1*300 = 2*300 = 600 -- Pretty obviously a 100% increase.
300 + 2*300 = 3*300 = 900 -- Pretty obviously a 200% increase.
300 + 3*300 = 4*300 = 1200 -- Pretty obviously a 300% increase.
300 + 4*300 = 5*300 = 1500 -- Pretty obviously a 400% increase.
Feel free to tear things apart and see how they work.
