How to combine percentages (Solely Simple Math Problem)
  • Thread starter Thread starter Fisher92
The discussion addresses the calculation of spilled power percentages from two frequency channels in a communications assignment. The user calculated the total power and spilled power for each channel separately and then combined them, resulting in discrepancies in the percentage of spilled power. The correct method for calculating the overall percentage involves summing the total powers and spilled powers from both channels before computing the percentage, which yields a more accurate representation of the spilled power. The example illustrates the mathematical reasoning behind the differing results and emphasizes the importance of using a unified approach for accurate calculations.
  • Understanding of power calculations in electrical engineering
  • Familiarity with frequency components and their significance in communications
  • Basic knowledge of percentage calculations
  • Ability to interpret and analyze data from multiple sources
  • Research methods for calculating combined percentages in power analysis
  • Learn about the implications of spilled power in communications systems
  • Explore the concept of power spectral density and its relevance
  • Study the impact of frequency modulation on power distribution
Electrical engineers, communications professionals, and students working on signal processing and power analysis in frequency channels.
Fisher92
The problem was actually for a COMMS assignment that I have finished with the exception of the very last easiest part.
They wanted percentage of power spilled into gaurd bands - have calculated all the powers now need the percentage...
I have two frequency components modulating the carrier and I have calculated power components. I end up with the following:
f(Hz), P(W) - Channel 1
5, 1
10,5
15,2
20,3
25,4
f(Hz), P(W) - Channel 2
5, 1
15,5
20,2
25,3
30,4
Anything above 20kHz is spilled power and I want to know the percentage of spilled power (no that's no my actual results)
The problem is that if I work out the percentages for channel 1 and 2 separately (& then sum) I end up with a higher percentage than if I just summed everything... What is the correct way to do this.
******Example may be easier to follow then my explanation*****
Channel 1:
Total power = 1+5+2+3+4W=15W
Spilled Power (>20kHz)= 4W
Percentage = 4/15*100=26.67%
Channel 2:
Spilled Power (>20kHz)= 3+4=7W
Percentage = 4/15*100=46.667%
CH1 + ch2 = 46.667+26.67=72% SPILLED
Combined
Total Power = 1+5+2+3+4+1+5+2+3+4=30W
Spilled Power (>20kHz)= 4+3+4=11W
Percentage = 11/30*100=37% SPILLED
Why is there a discrepancy? I get mathematically why this is giving me two different results but which 1 would be the power spilled?
Let's say you have 10 bucks and you lose all of it. Your loss is 100%.
I also have 10 bucks but I am lucky and I keep my stash. My loss is 0%.
Using your method #1, our total loss is 100% + 0% = 100%. Does this seem correct to you? (Note also that if my loss were anything > 0%, our total loss would be > 100%)
Using your method #2, our total loss is (10 + 0)/(10 + 10) = 50%. Does this seem correct to you?
Likes 1 person
Thanks, I came to the same conclusion.
