How to compute the expansion of this congruence?
  • Context: Undergrad
  • Thread starter Thread starter LCSphysicist
    Expansion
The discussion revolves around computing the expansion of a vector field in the context of the Schwarzschild metric. Participants explore the mathematical formulation of the expansion, the construction of the B matrix, and the implications of kinematic decomposition in general relativity. The conversation includes technical details about covariant derivatives and the physical interpretation of the vector field.
  • One participant expresses confusion about constructing the B matrix for the vector field and mentions the challenge of decomposing it into trace and traceless components.
  • Another participant corrects the first by stating that the matrix representation is incorrect and emphasizes the need to consider connection coefficients when computing covariant derivatives.
  • A third participant suggests thinking about the physical meaning of expansion, shear, and vorticity in relation to the vector field's integral curves.
  • Further discussion includes references to a Wikipedia article on kinematic decomposition, with one participant noting the irrelevance of proper acceleration in this scenario.
  • There is a debate about whether the matrix should be purely antisymmetric or if it can have a symmetric part, with differing opinions on the nature of the matrix required for the computation.
  • Participants discuss the implications of using covariant derivatives versus partial derivatives and the importance of correctly identifying the components of the vector field.
  • One participant reflects on understanding the terms related to fluid dynamics and how they might apply to the vector field in question.
  • There is a consensus that the computation involves geodesics but disagreement on the necessity of affine parameters for this specific problem.
  • Another participant points out potential issues with the approach taken, including the need to lower indices on the vector field components before proceeding with the matrix computation.
Participants do not reach a consensus on the correct form of the B matrix or the nature of the components involved in the computation. Multiple competing views remain regarding the mathematical approach and physical interpretation of the vector field.
Limitations include unresolved mathematical steps regarding the construction of the B matrix, the treatment of covariant versus partial derivatives, and the handling of vector field components. The discussion reflects varying interpretations of the kinematic decomposition and its application to the problem at hand.
LCSphysicist
##u^{a}\partial_{a} = (1-3M/r)^{-1/2}(\partial_{t} + (M/r^3)^{1/2} \partial_{\theta})## in Schwarzschild metric. I need to compute the expansion of this vector field, but i am not sure how.
Adopting the fact that ##u_{a};_{b} = B_{ab} (1)##, i want at first to construct the B matrix, but i am having trouble here! I mean, technically we can write the B matrix as the sum of three Matrix: One with trace, and two traceless, in which one is symmetric and the other is anti symmetric. But, using (1) we will have $
\begin{pmatrix}
0 & U_{1,2} &0 \\
0 &0 &0 \\
U_{3,1}& 0 & 0 \end{pmatrix}}$, this certainly can't be decompose in the way i cited above. I am really confused :S. Any help?
Space news on Phys.org
LCSphysicist said:
Adopting the fact that ##u_{a};_{b} = B_{ab}##, i want at first to construct the B matrix, but i am having trouble here!
The matrix you wrote down is wrong. Check your math. Bear in mind that you are computing a covariant derivative, which means you need to take into account the connection coefficients.
As John Wheeler once said, before computing anything you should first figure out the answer. :wink:
In this case, you should think about what the expansion (or more generally, the expansion, shear, and vorticity, since all three are components of the kinematic decomposition and all three have useful physical meanings) means, physically, and what, physically, the vector field you are describing means. What kind of orbits around the central body are the integral curves of the vector field you describe? If you imagine a fleet of such objects, each following its own integral curve, what would an object in the fleet see its neighboring objects doing? And how does that relate to the expansion, shear, and vorticity?
PeterDonis said:
This Wikipedia article
Note that the article mentions a fourth quantity, the proper acceleration. For this particular scenario, however, that is zero and can be ignored. Can you see why?
PeterDonis said:
The matrix you wrote down is wrong. Check your math. You should end up with a pure antisymmetric matrix.
I edited the post and the matrix (I think we need actually a 3x3 matrix, since it is purely spatial). As you noted, i should end up with an antisymmetric matrix. But, the problem is that i didn't even started the math because i was puzzled with the derivatives. I mean, we have that the only terms that are nonvanishing are terms involving the derivative wrt r.
I think i can understand these terms when thinking about a fluid. It is confused because in theory i see that we can decompose in: ##\delta_{ab} \theta /3 + \rho_{ab} + \omega _{ab}##, i am not being able to do it here. I am pretty sure my matrix is wrong, but i can't see what step was wrong.
I will try to do the things slowly here because probably i missed some part of the theory.
Taking just the spatial part of the metric:
\begin{pmatrix}
U_{r,r} &U_{r,\theta} &U_{r,\phi} \\
U_{\theta,r} &U_{\theta,\theta} &U_{\theta,\phi} \\
U_{\phi,r} &U_{\phi,\theta} & U_{\phi,\phi}
\end{pmatrix} =
\begin{pmatrix}
0&0 &0 \\
U_{\theta,r}& 0 & 0\\
0 & 0 & 0
\end{pmatrix}
Following the wikipedia article ##{\dot {X}}^{a}={X^{a}}_{{;b}}X^{b} ## is zero here probably because we are dealing with geodesics, and i am assuming that we are using affine parameters.
Yes, I saw that, thanks!
No, it isn't. It's transverse, but it's not purely spatial, because surfaces of constant time in the coordinates you are using are not orthogonal to the vector field.
No, actually you shouldn't. The matrix will be traceless (which is actually sufficient to answer the title question of this thread), but it won't be purely antisymmetric; it will have a symmetric part as well. (I originally thought it would be antisymmetric but then realized I was wrong, I was thinking of a different, though related, vector field.)
Not necessarily. Remember that, as I said, we are talking about covariant derivatives, so you have to take into account the connection coefficients.
Yes, at least a fair number of the intuitions associated with a fluid will work here; you can think of the integral curves of the vector field as "flow lines" of the fluid. But you still need to think about how the "speed of flow", so to speak, varies with ##r##.
Yes.
Geodesics are geodesics whether you are using affine parameters or not. As it happens, we aren't going to have to worry about affine parameters at all for this particular problem; just cranking through the computation as described in the Wikipedia page will take care of it automatically.
This is already wrong in at least two ways.
First, as I noted in my last post, the matrix you are trying to compute is not purely spatial.
Second, as I noted in my last post, you are taking covariant derivatives, not partial derivatives, so you have to take into account the connection coefficient terms.
There is also a third potential issue: the components of the vector field you wrote down in the OP are the components of ##U^\alpha##, with an upper index; but what you need to compute the matrix are the components of ##U_\alpha##, with a lower index--i.e., the covector field that corresponds to your vector field. So you have to lower an index on the field first before computing the matrix. I suspect you haven't done that.
  • · Replies 54 ·
  • · Replies 30 ·
