How to concatenate strings in a MATLAB loop for input prompts
  • Topic: MATLAB
  • Thread starter Saladsamurai
    Matlab
8 replies · 3K views · last reply
Saladsamurai
This is so easy I am sure...but I have no idea how to look it up.
I want to execute a loop from i = 1 to N
During each iteration I want to prompt the user for the i-th input. Let's say, I want to ask for
x1, x2, x3, ..., xN.
I should be able to write something like:
Code:
for i:N
    x(i) = input(' Enter value of x' & i)
next
But the '&' does not seem to be the proper way to do this...
Anyone know this one?
Thanks! :smile:
for i = 1:3
x(i) = input([' Enter value of x' num2str(i) ': ']);
end
Wow! You're my hero right now matonski!
Now maybe I can get a little extra out of you? I am used to using
Code:
For i = 1:3
x(i) = input(' stuff ')
end
Can you tell me litle about your syntax? Why are the '[' brackets now required? as in your syntax
Code:
for i = 1:3
end
Thanks again!
Since i is a number, I had to use num2str to convert it to a string. Then, the brackets are used to concatenate the separate strings.
Excellent! So brackets are used to concatenate strings. Perfect!
Thanks again :smile:
What about this one?
I want to assign the value 5 to the variables x1,x2,x3 so I would like to be able to do something to the effect of
Code:
for i = 1:3
[x num2str(i)] = 5
Thanks!
EDIT: I just tried
strcat(x, num2str(i))= 5
and Horrible things happened! Haha...
Horrible things happened because you are trying to assign a number to a string. It's like trying to assign 5 to the number 4.
I suggest not naming variables that way and simply using x(1), x(2), etc. There's a way using the function eval, but that's generally frowned upon. Besides, using arrays let's you make use of all matlab's matrix functionality very simply and straightforwardly.
For example, if you wanted to just set x(1) through x(3) to 5, you could just do x(1:3) = 5
Alternatively, you could do this:
Code:
do i=1:3
  x(i) = 5
end
This is longer than the way matonski suggested, but it's more in line with many other programming languages.
Code:
do i=1:3
  x(i) = 5
end
Hmmm. I don't think this will do. This will set the i-th element of the array (vector) x to 5 for each value of i. Whereas I want to set one variable named 'x1' equal to 5 and 'x2' =5, etc
Edit: ok Mark, I see you were simply complementing matonski's post and thus are implying that I should use an array :smile:
