How to convert m meter into recoils
  • Context: Graduate
  • Thread starter Thread starter texophist
    Convert Meter
The discussion revolves around the conversion of recoil momentum associated with single photons into a width of a velocity distribution, specifically in terms of recoils. Participants explore the relationship between momentum, velocity, and how to express these concepts in different units.
  • Technical explanation, Conceptual clarification, Mathematical reasoning
  • One participant states that the single photon recoil can be expressed as momentum using the equation p = ħk, where k = 2π/λ.
  • Another participant questions the initial request, suggesting that expressing recoil in meters does not make sense and asks for clarification on the desired information regarding velocity change.
  • A participant clarifies their intention to calculate the width of a velocity distribution in recoils and provides a specific example involving pixel dimensions.
  • A proposed method outlines a three-step process to calculate the width in recoils, including determining recoil velocity and expressing the width of the velocity distribution in compatible units.
Participants generally agree on the need to express recoil in terms of velocity rather than distance, but there is no consensus on the best way to express the width of the velocity distribution in recoils.
The discussion includes assumptions about the definitions of recoil and velocity distribution, and there are unresolved aspects regarding the conversion process and the specific units to be used.
Readers interested in photon interactions, atomic physics, or those working on problems involving recoil momentum and velocity distributions may find this discussion relevant.
texophist
Hi
as the single photon recoil is p=hbar k
and k=2pi/lambda
What is it you want to know? The velocity change of an atom that absorbs or emits a photon?
Single-photon recoil can be expressed as a momentum or as a velocity. It doesn't make sense to express it as a distance (as your implying by asking about meters). Can you explain some more about what you wish to know?
yes yu are right,
I just want to calculate the width of a velocity distribution in recoils.
if e.g 1 pixel=2 micro meter, which is the width in pixel or microns,
how ca we express this width in recoils.
thanx
Here is a "3-step program":
1. Divide the recoil momentum by the atom's (or molecule's) mass. This gives you the recoil velocity:
vrec = hbar k / M
2. Express the width of the velocity distribution in velocity units, such as m/s. (Not in pixels or micro meters, that is not making sense to me.)
3. With the recoil velocity and velocity width expressed in the same velocity units, take their ratio:
[width in recoils] = vwidth / vrec
Thanx a lot
  • · Replies 18 ·
