How to count Spearman Rank order correlation
The discussion focuses on calculating the Spearman Rank Order Correlation for two sets of data. The user attempts to follow the method outlined on VassarStats, which involves ranking the data, subtracting corresponding ranks, squaring the differences, and summing them. They report achieving a correlation of approximately -0.93 using the online tool but struggle to replicate this result manually, obtaining around -0.90 instead. The user expresses frustration over the lack of detailed guidance on the calculation process and the impending exams. Understanding the calculation method is crucial for exam preparation.
Drudge
calculate the rank order correlation between the following data:
6, 5, 4, 2, 3, 3, 8, 3, 7, 6, 7, 5, 5, 4, 2, 7, 6, 2, 4, 6
4, 3, 6, 7, 6, 7, 1, 9, 1, 2, 3, 4, 5, 5, 7, 1, 2, 9, 5, 4
Following the output from http://www.vassarstats.net/corr_rank.html, given the ranks, then from each individual rank subtract the equivalent opposing / matching rank. Lastly, raise every subtraction to the power of two and sum up results:
Ʃ( #x_{i} - #y_{i} )^{2}
I have used the aforementioned online site to help my calculations, and have used the ranks given there, from the appropriate variables, to perform the previously described actions.
The answer is ≈ -0.93. This is confirmed by vassarstat.net. However, vassarstat does not give any explanation how to perform the rest of the problem.
I can only get ≈-0.90. After Ʃ( #x_{i} - #y_{i} )^{2}, I get 2529. Then I use the spearman rank order correlation equation 1 - \frac{6 * 2529}{20 * (20^{2} - 1)} ≈ -0.90
Anyone? Exams are just behind the corner and I can not figure this one out. Hate it if they would ask to use this in the test. It could be so simple if i could just understand
