How to Create an Executable in Intel Fortran Using Visual Studio?
2 replies · 3K views · last reply
MechEng2010
Hello all,
I am new to programming and fortran, I have Intel Fortran 9.1 and using this via Microsoft Visual Studio 2005. To start with I have found a simple exmaple from the a Intel Fortran 90 book. I seem to be able to run a debug, but can't seem to create an executable? Its my first time using Visual Studio and Fortran. Any help would be appreciated.
PROGRAM Sum_and_Average
! This program reads in three numbers and sums and averages them
IMPLICIT NONE
REAL :: N1,N2,N3,Average = 0.0, Total = 0.0
INTEGER :: N = 3
PRINT *, 'Type in three numbers, separated by spaces or commas'
READ *,N1,N2,N3
Total= N1+N2+N3
Average=Total/N
PRINT *,'Total of numbers is ',Total
PRINT *,'Average of the numbers is ',Average
END PROGRAM Sum_and_Average
For example the Intel Visual Fortran Compiler Documentation provides this information, but no more on how to do this... can anyone help?
"Creating Fortran Executables
The simplest way to build an application is to compile all of your Intel® Fortran source files and then link the resulting object files into a single executable file. You can build single-file executables using the ifort command from the command line. For Windows*, you can also use the visual development environment.
The executable file you build with this method contains all of the code needed to execute the program, including the run-time library. Because the program resides in a single file, it is easy to copy or install. However, the project contains all of the source and object files for the routines that you used to build the application. If you need to use some of these routines in other projects, you must link all of them again.
Exceptions to this are as follows:
If you are using shared libraries, all code will not be contained in the executable file.
On Mac OS* X, the object files contain debug information and would need to be copied along with the executable."
If you can run your code then you will almost certainly have created an executable. It may not be in the same directory as your Fortran - quite often in a sub-directory.
