How to detect neutrons using Helium 3
  • Level: Graduate
  • Thread starter Thread starter CraigH
    Helium Neutrons
9 replies · 4K views · last reply
CraigH
I understand that helium 3 has a very high probability of fusing with thermal neutrons, and the reaction produces tritium and hydrogen:
n + 3He → 3H + 1H + 0.764 MeV
however I do not understand how this reaction is detected.
Can someone please explain?
Thanks.
Tritium (hydrogen-3) is radioactive, with a half-life of about 12.3 years. It decays back into helium-3 by emitting beta particles. It also glows in the dark.
What SteamKing wrote is true. It's also irrelevant.
You have ionization in the gas when this reaction takes place. The ionization is detected just as it is in a charged particle detector.
As a more short-term detection method, you produce two high-energetic hydrogen nuclei, maybe together with a photon. They can be detected with conventional particle detectors (scintillators, for example).
Edit: Vanadium was a bit faster.
If it IS gas, naturally.
What kinds of excitations do fast hydrogen nuclei produce in helium 3? And which spectral lines do these emit?
(Helium is a notoriously poor solvent. Basically anything will precipitate... In helium 3, would solid diprotium float as it does in helium 4?)
Why is this? There are no strong magnetic fields or ionizing radiation present to cause the gas in the detector (e.g geiger tube) to ionise. Is it because the tritium and hydrogen have high kinetic energies (0.764 MeV) so they can "bump" into electrons of the atoms in the gas and knock them from their shell?
Helium-3 is a gas.
Spectral lines are irrelevant. It works by ionization.
Right. The fast reaction products are the ionizing radiation.
Think of it this way: you have a gas tube, just like a proportional or Geiger tube, but instead of the ionizing particle coming from outside, it's produced in the gas.
