How to Determine Elevator Height at Time T1?
11 replies · 7K views
Mr Davis 97
At t = 0, an elevator departs from the ground with uniform speed. At time ##T_1## a child drops a marble through the floor.The marble falls with uniform acceleration g = 9.8 m/s^2, and hits the ground at time ##t = T_2##. Find the height of the elevator time ##T_1##.
SUVAT Equations
Using the equation ##h = v_e T_1## and ##0 = h + v_e T_2 - \frac{1}{2} g T_2^2##, I was able to find the height in terms of ##T_1## and ##T_2##: ##\displaystyle h = \frac{g T_2^2}{2(1 + \frac{T_2}{T_1})}##
However, this gives the height in terms of ##T_1## and ##T_2##, but I need it in terms of ##T_1##. How should I go about doing that?
You need to find time t for the object to reach the ground after being dropped.
t is just the difference between T1 and T2.
I'm not seeing how I would find t...
T1 and T2 are given: T1 is the instant of time when the child drops the marble and T2 is the time when it reaches the ground. The time of fall is T2-T1. You have to use the time of fall T2-T1 in the second equation.
So now I have ##\displaystyle h = \frac{gT_1(T_2- T_1)^2}{2T_2}##, but this doesn't seem to really get me anywhere...
It is the solution. Both T1 and T2 are given data, and h is the elevator time at T1.
Reply
Ah! How did I miss that... Thanks!
:smile:
s=ut+1/2at^2
h=0+1/2*9.8*(T2-T1)^2
initial velocity of the ball related to the elevator is zero.
T2 is the time it took the ball to hit the ground (T2 is being measured through a different clock and it was started the instant ball stated falling through the floor.) not the final time when the event end (starting point being when elevator started to rise).
Mr Davis 97 said:
Find the height of the elevator time T1.
height of a time?
Not so. It is clearly stated that
Mr Davis 97 said:
At t = 0, an elevator departs from the ground … marble falls … and hits the ground at time ##t = T_2##.
Anyway, the thread is six years old.
