How to Determine Ellipse Axes from Cone Geometry?
  • Thread starter Thread starter femas
    Cone Ellipse
femas
Hi,
If the cone is cut with a plane such that an ellipse has been formed. Let's say the major axis is 'a' and the minor axis is 'b'.
Is there a way to find a and b from the geometry instead of getting them from the quadratic equation.
The inclination of the plane would give the ratio a:b & its distance from the vertex of the cone would give a. I would prefer to do this trigonometrically.
Thank you ... But can you give me an example.
The distance of the plane from the vertex of the cone as measured along the axis of the cone and the slope of the cone determines the semi-minor axis of the ellipse, while the inclination of the plane together with that distance determines the semi-major axis.
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
