How to Determine Forces in a 2D Truss Using the Joint Method?
3 replies · 4K views · last reply
togo
Truss diagram for Problem 3-184 with joints A, B, C, D and E on a horizontal line, members forming triangles, 40 in and 30 in and 25 in and 20 in dimensions, a 100 lb force to the right at E, and 500 lb and 600 lb loads pointing down at C and E.
Determine force of each member using joint method
T = F x D
Handwritten truss joint analysis on lined paper: a small truss diagram with joint E, members labeled 20 ft, 35 degrees, 20 deg, 38.5 ft, and 600 lb and 100 lb loads, with force diagram arrows labeled FED and FEC, and equilibrium equations Fy = 0 and Fx = 0 written below.
Answers are:
Fab 2465 T
Fbd 1200 T
Fbc 1375 C
Fdc 750 C
Fde 860 T (This one is what I tried)
Fce 649 C
Fac 1922 C
Thanks.
I moved this thread to the engineering homework forum as you're more likely to get responses on this type of problem there.
You might want to forgo using a scanned image of your work, especially one so large, since it makes your post inconvenient to read.
T = F x D
Answers are:
Fab 2465 T
Fbd 1200 T
Fbc 1375 C
Fdc 750 C
Fce 649 C
Fac 1922 C
Thanks.
You have the wrong geometry for the slope of member DE...the rise is 20 but the run is 25, not 55...
Always determine joint support reactions first using the equilibrium equations; then start at the easiest joints next when determining forces using the method of joints. Also be sure to indicate T (force of member on joint pulls away from joint) or C (force of member on joint pushes toward joint).
thanks for that, encouraging to know I'm on the right track. Something did seem wrong with the trig
