The discussion revolves around determining the magnetic field along the z-axis between two Helmholtz coils, which consist of two circular loops of radius R carrying current I in the same direction. The loops are positioned along the z-axis with their centers at z=+/-s/2.
- Exploratory, Assumption checking, Conceptual clarification
- Participants explore the relationship between the magnetic field of a single loop and that of two loops, questioning whether a factor of two should be included due to the presence of both coils. There is also discussion about the implications of the different z-values for each coil when calculating the magnetic field.
The discussion is ongoing, with participants sharing their thoughts on how to approach the problem. Some guidance has been provided regarding the need to consider the positions of the coils when applying formulas, but no consensus has been reached on the exact method to use.
Participants note confusion regarding the distance between the coils, specifically whether it should be considered as the radius or diameter of the coils, which has implications for their calculations.
