How to Determine Whether a Beam Is Stable
  • Thread starter steevee
    Beam Stable
1 reply · 3K views · last reply
steevee
Hi all,
I have a HW question which is about a simple beam the beam carries a uniform load across its whole length and has two concentrated loads. The beam looks something like this:
O____________I____________________I_________________X
Where: I = concentrated loads
O = roller support
X = hinge support
I was taught that before I can start any calculations that I must check whether the beam is stable or not and whether the beam is statically determinate or not. The problem is I'm not sure how to determine this.
I understand that the hinge support is fixed and the only freedom it gives is rotation in the z-axis and the roller is also free to rotate in the z-axis but is also free to translate in the x-axis.
1. Homework Statement
Hi all,
I have a HW question which is about a simple beam the beam carries a uniform load across its whole length and has two concentrated loads. The beam can be viewed in the attachment.
2. Homework Equations
3. The Attempt at a Solution
I was told that before I could start any calculations that I need to check whether the beam is stable or not and whether the beam is statically determinate or not. How do I check these factors?
