Undergrad How to Expand the Inverse Function of a Given Function?
The discussion focuses on how to expand the inverse function of a given function, specifically addressing whether the same expansion rules apply to inverse functions as they do to regular functions. It is established that if a function has a continuous first derivative, the expansion for its inverse can be similarly expressed, but caution is advised regarding the conditions of the inverse/implicit function theorem to ensure a local differentiable inverse exists. The conversation also touches on the differentiability of inverse functions, with examples like the square root function illustrating potential issues at specific points. Ultimately, the participants emphasize the importance of clarity in defining what is meant by having an inverse function, as interpretations can vary significantly. The discussion concludes that understanding these nuances is crucial for accurate mathematical communication.
kent davidge
If I'm given a function ##f(x)##, say it has continuos first derivative, then I expand it as ##f(x + \Delta x) = f(x) + (df / dx) \Delta x##. If instead, I'm given ##f^{-1}(x)## how do I go about expanding it? Will this be just ##f^{-1}(x + \Delta x) = f^{-1}(x) + (df^{-1} / dx) \Delta x##?
Well, I'd have to imagine that since an inverse function is simply another function it should hold that rules for normal functions hold for inverse functions. I'd say yes then.
Likes kent davidge
We generally have $$f(x_0+v)= f(x_0) + J_{x_0}f\cdot v + r(v)$$
We have the same equation for ##f^{-1}(x)##, i.e.
$$f^{-1}(x_0+v)= f^{-1}(x_0) + J_{x_0}f^{-1}\cdot v + \tilde r(v)$$
So yes, you can write it this way, just be careful with ##\dfrac{df^{-1}}{dx}##.
Likes Harperchisari and kent davidge
But I think you first need to make sure the conditions of the inverse/implicit function theorem are met, so that you know you have at least a local (differentiable) inverse. Consider the problems, e.g. of ##\sqrt x## near ##x=0##. And then maybe you can use the chain rule on ##f(f^{-1}(x))=x##
Not in the situation stated in the OP ...
kent davidge said:
If instead, I'm given ##f^{−1}(x)## ...
... then we can write down the Weierstraß equation simply for this given function. How to compute the derivative given the derivative of ##f## is another question. If ##f^{-1}## is given, then we do not have to bother about ##f##.
How do you know the inverse is differentiable?
I can't think at this point of a counter, but I don't see how we can know for certain under the conditions in the OP.
By inspection. Given ##f^{-1}## means to me, given a function ##x \longmapsto f^{-1}(x)## and not given that ##f## has an inverse. I consider it as just another function, since this was what I read from post #1. In your example with the square root, I assume that a sign is given. And ##x \longmapsto +\sqrt{x}## is differentiable on ##(0,\infty)## regardless whether it inverts ##x \longmapsto x^2## somewhere or not.
But don't we need the inverse to be defined in a neighborhood of a point, as in the case of ##\sqrt x## at ##x=0##?
Why? ##\sqrt{x}## isn't differentiable at ##x=0##, so what?
But it is invertible there. EDIT: Why don't we take the discussion elsewhere to avoid disrupting this one further?
But who cares?
means to me: Consider ##f^{-1}\, : \,x \longmapsto +\sqrt{x}##.
Given a function, not given the fact that ##f## is invertible. These are two different statements. I admit that the OP could be read differently, but I read it as if ##f^{-1}## was explicitly given. And in this case I can write
fresh_42 said:
$$f^{−1}(x_0+v)=f^{−1}(x_0)+J_{x_0}f^{−1}⋅v+\tilde r(v)$$
with ##x_0 \in (0,\infty)## in case of ##f^{-1}(x)=\sqrt{x}##, i.e. ##x_0 \neq 0##.
I think the question for the OP has been settled. The rest of the discussion is a very good example how language can be read differently and why accuracy is so important! In the end the whole debate is about what is meant by ##f^{-1}## is given: as a function in its own right (my interpretation) or as the inverse function of ##f## (your interpretation). But what should is given mean if you only relate to the existence?
  • · Replies 25 ·
