How to Find Critical Points of function f(x,y,z)
  • Context: Graduate
  • Thread starter Thread starter Gh. Soleimani
The discussion revolves around finding critical points of a function of three variables, specifically focusing on the conditions under which local maxima, minima, and saddle points can be identified. Participants explore the implications of first and second partial derivatives, as well as the properties of the Hessian matrix.
  • One participant questions how to proceed in finding critical points when the first partial derivatives do not yield any solutions.
  • Another participant identifies specific points where the first partial derivatives are zero, suggesting that critical points exist at (x, -5, 0) and (x, 0, 0) with x being arbitrary.
  • Concerns are raised about the validity of the gradient derived from the first partial derivatives, noting that it cannot represent a gradient of a function due to a non-zero curl.
  • A participant introduces a corrected function and its corresponding first partial derivatives, asserting that critical points cannot be found due to conflicting conditions.
  • Some participants agree on the values of the first partial derivatives but dispute the claim that there are no critical points, proposing that critical points exist along specific lines in the x-z plane and at y = 1.
  • Discussion includes the formulation of a matrix equation derived from the first partial derivatives, with uncertainty expressed about its utility in finding eigenvalues.
  • Participants discuss the properties of the Hessian matrix, including its determinant and implications for the nature of critical points.
  • One participant suggests alternative methods, such as data analysis models, for identifying local extrema.
  • Concerns are raised about the symmetry of the Hessian matrix, which is noted to be a requirement that is not met in this case.
Participants express disagreement regarding the existence of critical points, with some asserting that they do exist while others maintain that they do not. The discussion remains unresolved on this matter.
There are limitations regarding the assumptions made about the function and its derivatives, as well as the implications of the Hessian matrix's properties. The discussion reflects uncertainty about the validity of the gradient and the conditions under which critical points can be identified.
Gh. Soleimani
TL;DR
undefined critical points for first partial derivatives
Hi everybody
If we have not any answers for critical points after first partial derivatives equal to zero, how can we continue to find local MAX, local MIN and Saddle point?. For example: Suppose we have below equations for first partial derivatives:
∂ƒ/∂x = y + 5 , ∂ƒ/∂y = 2z , ∂ƒ/∂z = y
As you can see, for ∇ƒ= 0 , there are not any answers (undefined)
The three first partials are zero at (x, -5, 0) and (x, 0, 0), with x being arbitrary.
There is a fundamental problem here: [itex]\nabla \times (y + 5, 2z, y) = (-1,0,-1)[/itex] is not zero, so [itex](y + 5, 2z, y)[/itex] cannot be the gradient of a function.
[itex]y + 5[/itex] and [itex]y[/itex] do not vanish simultaneously.
Yes, I understand that.
Sorry. I think that I took a mistake to introduce the function. First of all, let me write true function as follows:
ƒ(x, y, z) = x +yz - xy
∇ƒ = (1-y) i +(z-x) j + y k
where:
∂ƒ/∂x = 1 - y =0
∂ƒ/∂y = z - x =0
∂ƒ/∂z = y =0
As you can see, there are not any answer for critical point because we have: 1- y =0 , also y =0
My question is: Can we make below H - matrix and evaluate eigenvalues?
I agree with your values for the first partials; namely, ##f_x = 1 - y, f_y = z - x; f_z = y##, but I disagree that there are no critical points.
The three first partials are zero at on the sets of points {(x, 0, x)} and {(x, 1, x)}, where x is arbitrary. The first set is a line in the x-z plane and the second set is a line in the plane y = 1.
Setting the first partials to zero results in the following matrix equation, but I'm not sure that doing this is helpful or why you need to find eigenvalues.
##\begin{bmatrix} 0&1&0 \\1&0&-1 \\0 & 1& 0\end{bmatrix} \begin{bmatrix} x\\y \\ z\end{bmatrix} = \begin{bmatrix} 1\\ 0 \\ 0\end{bmatrix}##
Thank you so much for your answer.
Finally, I need to obtain local minimum, local maximum and saddle points. As you know, we have to use Hessian matrix which will be made by second derivative. In fact, to examine eigenvalues of H - matrix in critical point says to us where is local minimum and local maximum.
##|H| = \begin{vmatrix} 0&1&0 \\1&0&-1 \\0 & 1& 0\end{vmatrix}## does not depend on the values of x, y, or z. What do you get for |H|?
According to this wiki article, https://en.wikipedia.org/wiki/Hessian_matrix, if det(H) = 0 at a critical point, the critical point is degenerate. If det(H) is not 0, the critical point is non-degenerate.
Yes. You are right. Here, the eigenvalue of the “H” matrix is equal to zero; therefore, the test is inclusive, and I have to use a contour map to obtain the local minimum/maximum and saddle point.
But perhaps there is another way, which is to utilize some data analysis models by machine for a selected domain.
A Hessian matrix must be symmetric; this matrix is not. This is a consequence of the problem I noted in my earlier post: the vector field specified by the OP is not the gradient of a scalar function.
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 32 ·
