How to find the resultant of 3d vector?
The resultant of a 3D vector expressed as ai + bj + ck is indeed calculated using the formula sqrt(a^2 + b^2 + c^2), which represents its magnitude. This can be explained mathematically through the application of the Pythagorean theorem in three dimensions. By visualizing the vector in a 3D space, a right triangle is formed, allowing the use of the distance formula to derive the hypotenuse. The magnitude reflects the length of the vector from the origin to the point (a, b, c). Understanding this concept clarifies the distinction between magnitude and resultant in vector analysis.
asanka000
i have a vector ai+bj+ck
is the resultant equal to sqrt(a^2+b^2+c^2). if so how do i explain it mathematically?
i know the resultant of a 2d vector is equal to sqrt(a^2+b^2) and it can be proved from pythagoras theorem? any ideas??
That is not resultant that is intensity. Yes if you have vector \vec{A} then
|\vec{A}|=\sqrt{\vec{A}\cdot\vec{A}}
first of all, when u say u have a vector ai+bj, sqrt(a^2+b^2) gives u the magnitude of the vector, u shouldn't call it "resultant" as such,
as far as a 3d vector is concerned u can find its magnitude using Pythagoras theorem only..
Imagine the vector (a line with the arrow mark) ai+bj+ck, in a xyz space. Then imagine u have drawn a plane consisting the vector and perpendicular to the xy plane, then u can think of a rt triangle OAB being formed with co-ordinates, O(0,0,0); A(a,b,0); and B(a,b,c). The height of the rt triangle is 'b', and its base length is nothing but sqrt(a^2+b^2),[by distance formula]. therefore the length of the hypotenuse of the triangle OAB is sqrt(a^2+b^2+^c).
this is the magnitude of ur vector ai+bj+ck!
i hope u got it!
  • · Replies 0 ·
