How to Find the Volume of a Cubic FCC Unit Cell Using X-Ray Diffraction Data
  • Thread starter Thread starter Dampi
    Ray
The volume of a cubic FCC unit cell, specifically for copper, can be calculated using X-ray diffraction data measured at a wavelength of 1.5406 angstroms. To determine the volume, one must first find the lattice constant 'a' by indexing the diffraction peaks at angles of 43, 50.5, 74, 90, and 95 degrees (2Theta). Utilizing Bragg's Law (2dsin(theta) = n(Lambda)) and the formula for d spacing (d = a/SQRT(l^2 + k^2 + h^2)), the average lattice constant can be derived from the indexed peaks. The final volume is then calculated using the formula V = a³.
  • Understanding of Bragg's Law and its application in X-ray diffraction.
  • Familiarity with Miller indices for crystallographic planes.
  • Knowledge of cubic FCC unit cell structure and properties.
  • Ability to interpret X-ray diffraction data and peak indexing.
  • Learn how to index peaks in X-ray diffraction data using the provided paper.
  • Research the calculation of lattice constants from diffraction data.
  • Study the relationship between Miller indices and allowed reflections in FCC structures.
  • Explore advanced techniques for analyzing X-ray diffraction patterns.
Materials scientists, crystallographers, and researchers involved in X-ray diffraction analysis, particularly those studying metallic structures like copper in FCC configurations.
Dampi
The question I'm confused about it below:-
A unit cell of copper is cubic FCC. X ray data was measured at Lambda= 1.5406 angstroms. What is the volume?
I think to find volume, I need to find lattice constant which is the length of the unit cell.
The peaks were given and they are at 43, 50.5, 74, 90 and 95 degrees. These are angles of 2Theta.
Do I need to find the crystallographic planes which the angles are reflected from? If so how?
I know how to use Bragg's Law and find d spacing. 2dsin(theta)= n(Lambda). Also d= a/SQRT(l^2 + k^2 + h^2) where a is the lattice constant. and l, h and k are Miller indices of the plane.
I think as you mentioned, first you need to index the peaks then find 'a' from each peak and take a average of all 'a's. Then a3 will be the volume.
You can index easily.
please see this paper..
you will know how to index peaks:
http://arxiv.org/a/thirugnanasambandan_t_1
see 'X-Ray Diffraction Studies of Copper Nanopowder'
I hope your problem will be solved.
Thanx for the reply.
How do you find that constant (on the paper) to divide by so that 3rd column becomes an integer? (eg. 46=184-138) ??
i don't have all of the data from x ray diffraction. how do u assign the peaks to the specific planes? so confused :(
Oh it is clearly mentioned in that paper..
you need to find a constant (any constant) such that 3rd col. will becomes an integer..you have to try..1st take the 1st value (138), then 2nd (184), then 3rd (366),then the difference between 1st and 2nd..
Homework problem: Just play with it...you will get a const.
and now you know whether FCC or BCC and therefore you know which is allowed and forbidden reflections.
Now you can tell the reflection...for eg., 3 has 1 1 1, 4 has 2 0 0, etc (see remarks in that paper)
12K
