How to Implement Laplace Expansion in Fortran for Matrix Determinants?
2 replies · 2K views
kinbeat
Hi, I'm dealing with an exam problem (which i have 8 days to solve, with no outside help limitations), which is to write a fortran95 program that solves linear systems.
the first part asks to find the determinant of a NxN matrix with the laplace expansion, implementing it as a recursive function.
this is what I've done so far
module prec
integer, parameter :: rk= selected_real_kind(6)
end module prec
module lap
use prec
implicit nonecontains
recursive function det(a) result (d)
real(kind=rk), intent(in), dimension(:,:) :: a
real(kind=rk), allocatable,dimension(:,:) :: b
real(kind=rk) :: d
integer ::i,n
n=0
b(1:i-1,1:n) = a(1:i-1,2:n)
b(i:n,1:n) =a(i+1:n,2:n)
if (size(a) > 2) then
do i=1,n
d= ((-1)**(i+1))*a(i,1)*det(b)
end do
else
d = a(1,1)*a(2,2)-a(1,2)*a(2,1)
end if
end function det
end module lap
program sistema
use lap
real(kind=rk), allocatable, dimension(:,:) :: c
real(kind=rk) :: z
integer ::j,m
print*,'Inserisci la dimensione della matrice'
read*,m
allocate(c(m,m))
print*, 'inserisci i coefficienti della matrice'
read*, c
do j=1,m
print*,c(j,:)
end do
z=det(c)
print*, z
end program sistema
but the compiler gives me this error:
error 112, reference to undefined variable, array element of function result (/undef)
LAP!DET - in file matrice.f95 at line 18 [+00aa]
main - in file matrice.f95 at line 51 [+0521]
what am i not seeing?
Hi kinbeat. :welcome:
Code:
integer ::i,n
n=0
Does i have a value at the stage of being used on the 3rd line here?
ehi there!
yeah, i got a bit further now, i realized i didn't declare the n.
now i get the "nonconformant arrays" error, at that line, "
b(1:i-1,1:n) = a(1:i-1,2:n)what I'm trying to tell the compiler is that the matrix b is a minus the i row and first column.
now i changed that part so it looks like this:
recursive function det(a,n) result (d)
real(kind=rk) :: d
integer ::i
integer, intent(in)::n
do i=1,n
d= ((-1)**(i+1))*a(i,1)*det(b,n)
end do
else
end if
