How to integrate this function?
3 replies · 2K views
Mutatis
I've got to integrate the following $$ \int dx =\int \frac {d\phi} {\phi \sqrt {1 - \phi²}}. $$
[/B]
I already know the answer but not how to get it. The answer that I got from solution is ## x = \operatorname {arcsech}{\phi} ##.
I've used two apps to help me get this answer. First I did it using Mathway and I got:
Then, WolframAlpha told me that ## x = \operatorname {arcsech}{\phi} ## is equal to:
After that I took that first equation in the first image and with some algebraic manipulations I got:
So I don't know how to procedure beyond here. This was the closest I achieved from the final answer.
[/B]
View attachment 227957 .
View attachment 227958 .
View attachment 227959 .
One approach would be to use a trig substitution, with ##\sin(u) = \sqrt{1 - \phi^2}##, and ##\cos(u)du = \frac{-2\phi d\phi}{\sqrt{1 - \phi^2}}##. The result you get probably won't look like the solution you show, but it should be equal to the solution above within a constant.
You dropped a sign somewhere. The derivative of arcsech is the negative of the integrand.
I'd use the substitution ##\phi = \cos u##. It's pretty much the same as Mark's suggestion, but it makes the algebra a little simpler.
Thank you guys! I'm going to try to do it again watching the signs and doing what you've said!
