How to make the deflection equation at any point along a snow ski profile?
  • Context: Undergrad
  • Thread starter Thread starter Skierman
    Deflection Point
The discussion focuses on developing a deflection profile for a snow ski, specifically at 50 mm increments along its length. Participants explore the complexities introduced by varying widths and heights at different cross-sections, which affect the flexural rigidity (EI) of the ski. The conversation includes considerations of load distribution and material properties.
  • One participant is attempting to create a deflection profile for a ski, noting that the varying EI at each cross-section complicates the calculations due to the need for second-order derivatives.
  • The participant assumes a uniform modulus of elasticity (E) for initial calculations, planning to incorporate material variations later.
  • Another participant inquires about the support conditions and suggests that a diagram would clarify the setup.
  • A third participant describes the loading scenario as a three-point load, with the load being slightly off-center, and specifies the reaction points at the ski's effective edges.
  • One participant proposes a differential equation for the deflection and questions whether simplifying assumptions typically used in beam theory are applicable given the ski's loading conditions.
  • Concerns are raised about ensuring that bending stresses remain within allowable limits under the specified load.
  • Discussion includes the need to discretize the varying modulus of rigidity and suggests numerical methods or finite element analysis (FEA) as potential approaches for solving the problem.
Participants express various approaches and considerations, but there is no consensus on a specific method or solution for calculating the deflection profile. Multiple viewpoints on handling the varying EI and loading conditions remain unresolved.
The discussion highlights the complexity of the problem, including the dependence on the ski's geometry and material properties, as well as the need for numerical methods due to the changing EI. Assumptions about uniform material properties and the applicability of standard beam theory are also noted as potential limitations.
Skierman
I am trying to figure out how to do a deflection profile for a snow ski profile at 50 mm increaments along the ski. Since the ski has different widths and heights at each crossection, the EI changes at each location making it a lot of 2nd order derivatives if I am not mistaken.
I am assuming that the ski thickness profile is a solid piece of wood so E is the same throughout the equation just to see if I can get to first base before I start adding in laminates and other material to the EI part of the beam equations.
The load across the beam is not quite centered so that throws another wrench in the gears. I am thinking that there will be about 33 crossections on the ski I am trying to do. The single load is 300 Newtons.
Is there there anyone that can lead me to a location that explains how I go about this or tell me how to approach this in some kind of spread sheet? Thanks
How is it supported. A diagram would be helpful?
This would be a typical 3 point load with the load being slightly off center. The reaction points are at the
effective edge of the ski which is the wide points at each end of the ski. The load is approximately 55% from the wide point of the tip.
I suspect you are going to have to use the following:
$$ \frac{ \frac{d^2y}{dx^2} }{ \left[ 1 + \left( \frac{dy}{dx} \right)^2 \right]^{(3/2)} } = \frac{M(x)}{E I(x)} $$
When we encounter this equation in engineering, we typically can neglect ## \frac{dy}{dx}## for structural beams. However, a ski, with a 300 N ( 70 lbf ) load... I have wonder if the simplifying assumptions are no more?
Have you checked the bending stresses don't exceed the allowable stress for the desired loading?
As for the changing modulus of rigidity, unless you can write ##I(x) = \frac{1}{12} B(x) h(x)^3## , you are going to have to discretize it as you planned. I would try to write the shape functions, and solve the single resulting equation numerically, but maybe the FEA analysis isn't too bad? Its something I haven't personally performed.
Thank you for you input
  • · Replies 18 ·
21K
29K
