How to Measure Potential Difference Across Series-Connected Batteries?
1 reply · 2K views
Lee33
How can I measure the potential difference across two batteries? For example, if I put the batteries end to end, so the negative end of one touches the positive end of the other. And let's say both batteries have 3 volts and let's denote point A to B as the point from one battery to the other.
##\Delta V = -\int^b_a\vec{E} \dot\ \vec{dL}##
So if the length of both batteries is 5 cm then do I put a point C in the middle of the two batteries and measure the potential difference separately from point A to point C then from point C to point A?
Physical size (length) is pretty much unrelated to the potential difference across a battery. Cell potential depends upon the chemistry, while current capability and capacity scale with the volume of the cell.
Take a look at the Wikipedia entry on battery sizes.
"Measure" implies a physical process of determining potential difference. In that case one simply takes a handy voltmeter, places its leads across the desired locations, and takes the reading.
