How to modify the following code?
  • Thread starter Thread starter winiepu
    Code
winiepu
I can compile the following code, but I can not run it in my computer. How do change it? Thanks.
module nrtype
INTEGER, PARAMETER :: SP = KIND(1.0)
INTEGER, PARAMETER :: DP = KIND(1.0D0)
INTEGER, PARAMETER :: I4B = SELECTED_INT_KIND(9)
INTEGER, PARAMETER :: I2B = SELECTED_INT_KIND(4)
INTEGER, PARAMETER :: I1B = SELECTED_INT_KIND(2)
END module
program mainp
use nrtype
implicit none
call xlocate
end program
subroutine xlocate
USE nrtype
IMPLICIT NONE
!INTEGER(I4B), PARAMETER :: n=3
INTEGER(I4B) :: i,j
REAL(DP) :: x
REAL(DP), DIMENSION(4) :: xx
REAL(DP), DIMENSION(2):: xlim,ab
!real(DP), external:: mylocate1
xx=(/1.0_DP,2.0_DP,3.0_DP,4.0_DP/)
x=1.5_DP
CALL mylocate(xx,x,xlim,ab)
write(*,*) ab
END subroutine xlocate
SUBROUTINE mylocate(xx,x,xlim,ab)
USE nrtype
IMPLICIT NONE
REAL(DP), DIMENSION(2), INTENT(OUT):: xlim, ab
REAL(DP), DIMENSION(:), INTENT(IN) :: xx
REAL(DP), INTENT(IN) :: x
INTEGER(I4B) :: k
INTEGER(I4B) :: n,jl,jm,ju
LOGICAL(I4B) :: ascnd
REAL(DP)::h
n=SIZE(xx)
ascnd = (xx(n) >= xx(1))
jl=0
ju=n+1
DO
IF (ju-jl <= 1) EXIT
jm=(ju+jl)/2
IF (ascnd .EQV. (x >= xx(jm))) THEN
jl=jm
ELSE
ju=jm
END IF
END DO
IF (x == xx(1)) THEN
k=1
ELSE IF (x == xx(n)) THEN
k=n-1
ELSE
k=jl
END IF
h=xx(k+1)-xx(k);
ab(1)=(xx(k+1)-x)/h;
ab(2)=(x-xx(k))/h;
xlim(1)=k;
xlim(2)=k+1;
END SUBROUTINE mylocate
The compiler said handle exception: Error while dumping state. If I make mylocate internal subroutine by using contain, I can compile and run it just like the following. It is so weird. Can someone explain this to me? Thanks.
module nrtype
END module
program mainp
use nrtype
implicit none
call xlocate
end program mainp
subroutine xlocate
USE nrtype
! USE nr
IMPLICIT NONE
INTEGER(I4B) :: i,j
REAL(DP) :: x
x=1.5_DP
write(*,*) ab
!j=mylocate1(xx,x)
!write(*,*) j
Contains
USE nrtype
IMPLICIT NONE
INTEGER(I4B) :: k
REAL(DP)::h
n=SIZE(xx)
jl=0
ju=n+1
DO
jm=(ju+jl)/2
jl=jm
ELSE
ju=jm
END IF
END DO
k=1
k=n-1
ELSE
k=jl
END IF
h=xx(k+1)-xx(k);
ab(2)=(x-xx(k))/h;
xlim(1)=k;
xlim(2)=k+1;
What I would do is put a bunch of WRITE *,* statements in xlocate and mylocate to display the value of variables. (I'm assuming you want to get the code in post 1 to work.) Before you run this code, go through and predict the values of all variables. After that run the code with the WRITE statements, and see if the values displayed match what your hand calculations predicted.
